Results 1 to 12 of 12
Thread: advancing timming for perfomance
    DX User jdm4life's Avatar
    Oct 2011
    1987 honda accord dx mt
    indiana
    i herd i could advance my timming couple degreez to gie it a little more pep i have read threads but could i get more details thanks
    87 accord dx mt
    Re: advancing timming for perfomance
    you will need an adjustable cam gear. sometimes they pop up for sale every now and then
    3Geez Veteran gfrg88's Avatar
    1986 Honda Prelude 2.0Si-T
    A Mile High.
    I think he's talking dizzi timing.. Yes, advancing the distributor will smooth out the top end. You won't feel a huge gain on power and stuff. Start pumping premium fuel. Get a timing light, start advancing a degree at a time until you get some pinging then, go back a degree. Every car is different, you might be able to get it advanced 5 degrees, some more, less, etc....
    -Gio
    My E85 Turbo Build
    5280FEST
    start with the basics..
    Insure your cam belt timing is correct first, you say youve built honda before so that would not be a problem fo ryou
    Now after tha tis done t hen you can check your ign timinn a right.
    My experience has been you can usually go 2 to 4 degrees above factory spec if the motor can accept it without pining pre ignitshun ya right.
    at lest usee if n ignishun timin is even close to where is apposed to b ya right. If n it aint den it gonna feel like u draggin a lead sled on eny ting under 3k rpem ned any hep just axe
    A Mile High.
    engrish pleaz
    -Gio
    My E85 Turbo Build
    5280FEST
    2-3 degrees max if advancement is fine. I use a vacuum gauge when I time also. Reason is you need to be 18hg of vacuum when you adavance to much you start loosing hg volume there for is about 18hg. Little trick I learned from a tech
    Oct 2011
    indiana
    thanks guys il try this also id gues that i should turn the dizz toward the fire wall to advance it in my exsperiance right???
    87 accord dx mt
    A Mile High.
    If you use a timing light you'll find out
    -Gio
    My E85 Turbo Build
    5280FEST
    Quote Originally Posted by jdm4life View Post
    When you advance the idle will go up.
    Good trick.
    Interesting,and true so I won't disagree totally.
    However, it would be more interesting to see it explained as a theory which can be applied to a loaded engine. Also would there be potentially damaging varables if the idle air mixture was incorrect for whatever reason albiet FI or carbed engine?
    OP, ultimately less advance at higher rpm yields more power but then I don't want to confuse anybody in this thread since Im sensing we are discussing of idle advance to spin up the engine quicker.
    I get where you coming from. I did it on both carb and FI engines cause i had the same problem understanding. I dont get you on the loaded engine part, in a way i do but all your doing is knowing when valves are moved to much in a degree where you loosing manifold vaccum. All the vaccum gauge does is give you a guild on what is your limit. On a loaded engine it wouldnt matter. you have to try it. Nothing special in anyway your just knowing your motors limits. Factory specs are specs. You can only go a certain degree and thats it. This gives you the ability to go a bit more then spec. I felt a difference.
  1. Will a perfomance exhaust for a 90-93 fit?
    By neo_blue_accord in forum Performance
    Last Post: 01-04-2011, 03:16 PM
  2. 89 LX Timming Belt?
    By Misfit1 in forum Carburetor Tech
    Last Post: 02-23-2010, 10:34 PM
  3. Perfomance Parts
    By accord4ddx in forum Performance
    Last Post: 08-13-2008, 02:40 PM
  4. 86 ex-i perfomance questions
    By thirdgenonly in forum Performance
    Last Post: 01-26-2004, 09:51 AM
  5. Anyone have there timming belt break?
    By dhcarss in forum 3geez Accords
    Last Post: 02-11-2003, 08:46 PM
