Results 1 to 5 of 5
Thread: front brake pads with abs
    DX User rocketman's Avatar
    May 2006
    pocono mountains, pennsylvania, USA
    I've never changed pads on a car with abs. Our 2010 civic now is screeching (the wear indicators are singing) and I'm going to do the replacement tomorrow. I've done brakes on our '95 Civic and our '89 Accord many times, easy as pie. Looks like it will be just as easy on the '10. Anything special about abs when changing the pads? Only 23k on the car but my wife is the primary driver and loves to use the brakes. Rocketman
    3Geez Veteran gfrg88's Avatar
    1986 Honda Prelude 2.0Si-T
    A Mile High.
    Re: front brake pads with abs
    nope
    -Gio
    My E85 Turbo Build
    5280FEST
    I think it's the same process as for non-ABS. If you're going to bleed the brakes, you might want to do some reading on that because there could be some special process or tool you need.
    Sep 2010
    '88 Accord LX 4AT
    Louisville, KY
    And use care not to damage the wire, sensor, sensor ring, etc.
    Nov 2000
    The only thing I have done differently on cars with ABS is that I open the bleeder valve when pushing the piston back in to clear the new pads. Something I read a number of years ago said that you don't want to force old fluid backwards through the ABS hardware. I never tried to verify that, but I figured it woldn't hurt to open the bleeder valve and catch the fluid.
  1. Best brake pads?
    By Mattphi in forum Classic Honda Community Chat
    Last Post: 10-07-2005, 05:47 PM
  2. Brake Pads
    By mossimo817 in forum 3geez Accords
    Last Post: 01-17-2005, 05:39 PM
