Results 1 to 5 of 5
Thread: Rough idle and rough in high rpms
    DX User Tread's Avatar
    Aug 2011
    1988 Honda Accord Lx Piece (sold) 1986 Accord DX (Shouldn't have sold) 2002 Subaru Outback
    Michigan
    Ok, I'm new (a few months) and I have an 88 LX Sedan 235,000. I had the valves
    adjusted this spring, (it had compression on TWO cylinders!) it ran great at high rpms before and after. But recently it's been running really rough passed 5000rpm and starts losing power at 4 grand. Correct me if I'm wrong, most engines make MORE power the faster they spin! Like I stated before, I need to adjust the valves again.
    Another thing, how much does the MPG's drop when going full de'vac?
    Is there a way to advance the secondary so it engages sooner? (I don't think it's working at all)
    Anyway, Thanks in advance for any help on this!
    Re: Rough idle and rough in high rpms
    if it ran "great" on two cylinders and worse after the valve job I think your mechanic screwed up.
    the secondary won't open if you are reving it in neutral/park. It opens when it needs to under load.
    Eric
    LXi User Buzo's Avatar
    Dec 2010
    North of Mexico
    Quote Originally Posted by Tread View Post
    My car dropped from 24 MPG to 17 MPG.
    Power is nothing without control
    If you were running with valves adjusted so badly that two cylinders weren't compressing, you are looking at a head rebuild at the very least.
    Aug 2011
    Michigan
    When I said It ran great with two cylinders I ment it ran smoothly, not well. I feels like it's loosing power at 4500 rpm... Vacuum leak? I've noticed that if I punch it, The accelerator pump richens the mixture for a moment then it looses power. Is there a way to enrich secondary?
  1. Rough Idle
    By zildjian102 in forum 3geez Accords
    Last Post: 01-25-2010, 09:04 PM
  2. Rough Idle
    By rrhodes in forum 3geez Accords
    Last Post: 05-23-2008, 04:17 PM
  3. rough idle???
    By nskforlife in forum Carburetor Tech
    Last Post: 12-13-2006, 03:41 PM
  4. rough idle?
    By sgaddie in forum EFI Tech
    Last Post: 08-25-2004, 08:31 AM
  5. Very Rough Idle
    By hondamanlxi in forum Carburetor Tech
    Last Post: 07-29-2003, 06:14 AM
