sick ride man
sick ride man
very nice.
[QUOTE=H2289Acc;1081482]Thanks for the info. Sorry to be a pain in the ass, but do you have any pics of the door seal? Or if you can describe the location...I'm not exactly sure what I'm looking for.
Appreciate it![/QUOTE
Oh... the door seal!!! Duh!
Thanks. $50 for both fronts at the scrap yard and 25 bucks for the rears, believe it or not! and yes the seats are verrry comfy, especially the rears! Speedo is out of a Canadian SE-i as well as the door panels; I painted the speaker covers and replaced the carpet on the doors with black vinyl.
The sunroof has 4 drains, 1 on each corner. To get to the back ones you have to remove the sky (don't know if i can translate directly from Dutch, but you know what i mean, i hope).
The back ones exit the car just behind the back wheel. (mine do)
Removing the sky was not a funny job. Need to remove a lot if plastic first.
The front drain holes are visible when you open the sunroof a little.
I used a strong electrical wire to pierce them and a dishwasher tablet dissolved in hot water to flush all drains.
The front drains exit behind the front wheel in the fender. Just on height of where the Euro Accord has its round turn signal.
On the outside there is a small tube from soft rubber that clogs easy. When you take of the wheel and the mud flap you'll see.
The front left drain hose joins the electric antenna drain just before leaving the car there.
If you remove the fuse box, and you don't have a back problem, you must be able to reach it. Taking out the driver seat helps to.
I put 2 hose clamps on the Y split. And leaking gone.
Just put the garden hose on the left front drain hole and you know soon enough if you have the same problem i had.
I think you do.
Have fun.
Thanks, Fedor. I appreciate the help, man. This problem is driving me crazy!
I used a picture of your car as an example for nice 18 inch wheels, hope you don't mind.
https://www.3geez.com/forum/showthrea...07#post1082307
I give up.
Just out of curiosity does this car see any track duty?
