Have a few thousand miles now on my ’88 DX since the cylinder head repair. (Had run hot and blew the head gasket)
Been running well and had a nice smooth idle. For the past week started noticing the idle was not as smooth and idle speed had dropped. Initial diagnosis indicated that the carburetor had gone very lean. Idle speed would pick up about 500 RPM when sprayed with a little carburetor cleaner. Examined every vacuum line and pinched off all lines one at a time and did not find any vacuum leaks.
Pulled the carburetor off to remove the metal plug over the idle mixture screw. Backed the idle mixture screw out a couple of turns and reinstalled it. Idle was better but still very rough. Adjusted the idle mixture screw until peak RPM was achieved. Idle speed would still pick up about 300 – 400 RPM when sprayed with a little carburetor cleaner. Checked for vacuum leaks again – all hoses checked OK. Sprayed some carburetor cleaner right at the intake manifold gasket and found it has developed a vacuum leak, seems to be worse at cylinders 2 & 3. Loosened the two brace screws under the intake manifold and tightened all the nuts on the intake manifold. (The bottoms ones are fun to get to.) But did not find any really loose and the vacuum leak remains.
So I will need to replace the intake manifold gasket. But I’m wondering about a few things.
First, how did this happen? I cleaned both the head and the intake manifold mating surfaces. Torqued the intake manifold nuts in the specified sequence and to the specified torque (16 lb-ft) while the cylinder head was still off the engine. Gasket was from a Fel-Pro head gasket kit.
Second, is there enough give in all the hoses to pull the intake manifold back enough to fit a new gasket in place?
Any other suggestions to make this a successful and lasting repair? All suggestions are welcomed.
