This is for roodoo mainly, and you testing it on your carb would be great to confirm for me.
I have liquid (in my case carb cleaner), after I pour into the barrals of my weber 38, with the butterflies closed and car off (I was trying to let the cleaner soak at the bottom of the carb), the liquid comes out the primary and secondary throttle shafts. Included is a picture but I pretty much explained it in words. You can see where the cleaner dripped and cleaned the manifold.
Anyway if someone with a weber 38 could pour some carb cleaner to where it pools at the bottom of the carb (above the throttle plates) with the car off, and see if any of it comes back out via the throttle shafts? That would be great.
The manual says there is always a small bit of vac leak from the shafts so I assume liquid coming out would be normal with the car off also since there's no vacum.
Also, that's my linkage setup. No binding, EVER and full travel to WOT. Took me ages to figure it out without the original carb linkage.
