Results 1 to 1 of 1
Thread: coolant temp gauge goes high when turn key
    DX User rebuild's Avatar
    Jun 2010
    89 LXi
    Question coolant temp gauge goes high when turn key
    89 LXi around 550k miles
    Just turning the key makes the coolant temp gauge max out and stay there (whether I start the engine/drive or not) and it will only come back down when I turn the key back. On page 10-6 of the service manual I see a THERMO UNIT off to the side of the bleed bolt. Does that have to do with this problem? Engine sounds fine when it is running. No check engine light or codes. (A coolant temperature sensor would throw a code - correct?) I am thinking a faulty thermo unit does NOT throw a code.
    Thanks.
    AutoZone showed this for part #TU121:
    http://www.autozone.com/autozone/par...ier=19140_0_0_
    Not sure that AutoZone is the best place to get this part though.
  1. Replies: 29
    Last Post: 07-16-2012, 01:29 PM
  2. coolant temp sensor
    By Modemagic in forum 3geez Accords
    Last Post: 04-27-2004, 09:06 AM
  3. A/F gauge and Water Temp gauge
    By smufguy in forum 3geez Accords
    Last Post: 02-29-2004, 09:29 PM
  4. Coolant Temp Gauge?
    By CoAsTeR in forum Performance
    Last Post: 05-10-2002, 12:12 PM
  5. Coolant Temp Gauge
    By CoAsTeR in forum 3geez Accords
    Last Post: 05-08-2002, 10:20 AM
