How to move your battery to the trunk (This can get expensive).
Tools needed:
*18+ feet of 0-2 gauge wire(red)
*18+ feet of 0-4 gauge wire (black)
*(×2)1+ foot of 2-4 gauge wire (red)
*(×4) 0-2 gauge wire lugs
*(×4) 2-4 gauge wire lugs
*Wire snips (I used a hacksaw cause huge wire is challenging to snip)
*Wire crimpers
*Battery box
*Large Philips head screwdriver
*10mm socket
*Ratchet (for the socket)
Step 1isconnect your ground wire on your battery first then disconnect your power wire; in that order. now pull out your battery.
Step 2:Remove the bolts holding down the battery "shelf." (You can reuse this in the trunk to sit your battery box on)
Step 3: Run your 2 18 foot long power and ground cables to the front of a car from the trunk. (It's up to you how you run the wiring)[I ran mine on the far drivers side down on the floorboard]
Step 4:Put the 4 lugs on each end of the 18+ft. wiring. Put the 4 smaller lugs on the 2 1ft. Long wires.
Step 5:Now take the two 1ft. Wires and attach one end of them to the main power wire lug with a ¾" long ⅜" bolt&nut. Wrap the bolt/lugs with electrical tape(the goal is to keep this bolt/lug connection from shorting/arcing)
Step 6:Now attach your shorter power wiresne to your starter(10mm nut) and one to your underhood fuse box(large Philip head screw) (of course after you remove the old stock power wires).
Step 7:Find a spot on the motor or chassis you want to attach the ground to and attach it. {I Installed Mine Here:}
Step 8:Install your battery box however you want it positioned and put your battery in the battery box.
Step 9:Attach your ground wire, then your power wire to the battery, place the top on the battery box.
Step 10:Get in your car and drive to the local bank, walk in claiming you have a weapon and rob the bank. Installation complete.
[I installed another ground from my battery ground to the metal trunk chassis. This is optional but advisable]
