Results 1 to 12 of 12
Thread: Bad Clutch or Pressure plate Needs adjusting?
    LX User vteckiller's Avatar
    Oct 2011
    1989 Honda Accord LX-I
    OR
    Okay, first off the clutch was replaced and only driven.. Mediumly Race like for around 2-4 months, not none stop but 50% of the time probably.. It doesn't slip if i don't mash on it.. when i mash it only slips in 2,3,4,5. It's a 1989 honda accord lx-i manual transmission. second off. can i just remove the whole ride side suspension and what not if necessary and remove the transmission and replace the clutch the pop it back in.. and maybe third off.. is there a video somewhere?
    thanks for the help..
    Re: Bad Clutch or Pressure plate Needs adjusting?
    Quote Originally Posted by vtechkiller View Post
    Okay, first off the clutch was replaced and only driven.. Mediumly Race like for around 2-4 months, not none stop but 50% of the time probably.. It doesn't slip if i don't mash on it.. when i mash it only slips in 2,3,4,5. its an automatic 1989 honda accord lx-i. second off. can i just remove the whole ride side suspension and what not if necessary and remove the transmission and replace the clutch the pop it back in.. and maybe third off.. is there a video somewhere?
    clutch in a automatic ?!?!1
    SEi User Hauntd ca3's Avatar
    Sep 2007
    1988 ca3 si exclusive
    new zealand
    x2
    Oct 2011
    OR
    x2
    my bad been busy and stressing.. its an manual.. i believe the clutch is fried.. i got a tranny shop like 15min from my house but i aint chancing that shit breaking down the road.. and now im stuck.. and for the safety of everyone and myself.. ill just do it at home.
    Its a cable clutch its adjustable.See if can adjust it out.
    Oct 2011
    OR
    So i need to loosen the clutch cable? cause if the cable is too tight its apply the clutch? and if it don't slip in first but every other gear why is this? the design in a clutch/transmission allows first to be super strong. and what not?
    LIFE IS SHORT, DRAG IT OUT!
    With the clutch out the cable will have "free play" of like 10 mm. I forget the setting. The clutch arm will be loose on the cable. If i think of it today ill pop a picture of mine. Its set that way so the pressure plate is squeezing everything together when you let off.
    Slipping in high gears is just the gear ratios are higher so there's more leverage(strain) on the clutch.
    id adjust it out and see if you can save it.
    Oct 2011
    OR
    Right right.. more power in sense for the pressure plate to try and grab.. but its weird.. ill see if i cant pop up a pick of mine.. the cable is like tight but not like omg tight.. if i grab it there is no slop.. its tense all the time.
    http://i38.photobucket.com/albums/e1.../91-12-4-1.jpg
    pretty close i just did a google search.
    it should be pretty loose feel where it hooks to the arm.
    Oct 2011
    OR
    Right right.. well i loosened the cable at the round clutch cable mounting spot or whatever, and i spun it counter clockwise and now my clutch grabs way sooner and feels way better but im not use to the feeling of it so i don't like it atm.. but it don't slip anymore.. im more curious on to how long i've been slowly burning my clutch and not knowing it cause it wasn't noticably bad..
    Aug 2011
    89 accord dx
    waycross,ga
    what would cause this in a automatic 89 dx accord?mine just stopped today.from park to drive and back,no catch?
    Oldman you would be better to start your own thread since its a different question.
  1. Clutch, Pressure Plate and balancer bolts
    By MessyHonda in forum Classic Honda Community Chat
    Last Post: 01-03-2008, 09:05 AM
  2. 89lxi tranny/clutch and pressure plate
    By sjsjbb in forum 3geez Accords
    Last Post: 03-06-2006, 09:26 AM
  3. clutch/pressure plate problem
    By MattsAccord in forum 3geez Accords
    Last Post: 02-09-2005, 10:17 PM
  4. pressure plate problems
    By dXsquared in forum 3geez Accords
    Last Post: 09-19-2002, 04:51 PM
  5. clutch pressure plate ?
    Last Post: 08-12-2002, 02:54 AM
