Page 16 of 44 FirstFirst ... 612131415161718192026 ... LastLast
Results 376 to 400 of 1084
Thread: Tdurr's round two!
  1. #376
    Re: Tdurr's round two!
    Awesomeness!
    Got bored and bolted this stuff up.
  3. #378
    89T's Avatar
    Apr 2004
    just loading a basemap for my obd1 swap. Neptune rtp ftw!
    i cant wait man.. i so cant wait.
    Super stoked for you Tim. ..
    Sent from my SPH-D710 using Tapatalk 2
    un-motivated!
    3GR
  4. #379
    Thanks my man, im excited too. I just waitin on my last few parts then ill be dropping in the spare motor and going obd1. Then ill set up a date for tuning.
  5. #380
    Awesome progress! Can't wait to see the final results, and vids, and pics, and dyno charts, and time slips, and track vids!
  6. #381
ID:	5560What is the orange robot thing?
  7. #382
    Ooooo the memory's lol
    bwahahaha good eye there. That is something my rommate got from his job. its to move concrete slabs around easy. i just sat one of my beer bottles in it instead of the trashcan.
    but vids and all that stuff will be posted in due time. I have a sony Action cam so ill take some incar vids of things once i get a good mounting place for it.
    but small update.
    Got my head back from the machine shop yesterday. valves and seats have been recut so its gonna seal sexy like. no P&P yet. im gonna practice on the spare heads i have once this one goes in the car. I also got the b16 manifold installed. I messed up drilling the holes so i took it to a machine shop to get the bad boy fixed. Its on the head now but im only using 7 of the 8 studs(it shouldnt hurt a thing). I also got extended intake studs. A friend of mine told me about the problems people have when they install a thermo gasket and I didnt want to run into them so i spend the 30 bucks for the kit and picked them up. Its a 30mm stud kit from a ebay store called SickSpeed. Pretty simple stuff but its nice looking. Hopefully this weekend ill be prepping the new motor to get dropped into the car and go obd1 at the same time. I dont think ill be boosted by the end of the month but its okay. I'm not in a rush at all.
    now onto the pics:
    Longer intake studs
    old intake stud vs new
    it ends up looking like this
    Fresh head
    so you can see the seats were recut, he left the blue on it haha
    manifold installed
  9. #384
    cygnus x-1's Avatar
    Chicago area
    When you get this thing up and running, watch those intake manifold nuts like a hawk. When I tried using a nylon insulator gasket I had terrible problems with the nuts loosening up, which would screw up the alignment of the ITBs. With your common plenum type manifold it may not be as much an issue, but keep an eye on them at least for the first few runs.
    C|
  10. #385
    I could just hit them with blue threadlocker ahead of time...
  11. #386
    cygnus x-1's Avatar
    Chicago area
    That should work. You might want to lock the studs into the head as well, otherwise they will unscrew with the nut.
    C|
  12. #387
    i had a nice thermo gasket fucking thing leak all the nuts where loose (as in you grab em and turn em off) yea i was like wtf. that's my bad on my part for not applying loctite o well. watch them bitches bro but i like those studs. would you stop giving me ideas damnit lol
    Thanks for the heads up guys. And rendon, someone else gave me that one haha
    I might red thread lock the studs to the head just to be safe.
  14. #389
    Hash_man_Se_i's Avatar
    Calgary, AB, Canada
    progress is looking real good! Can;'t wait to see this setup running!
  15. #390
    Very cool stuff.
  16. #391
    Got this finally:
    so now its time to prep the motor I got for light boost. Ill be starting on this prob next week. I have to go to drill this weekend kinda bummed out on that but its okay. Its only a few more days. I cant get too far because the clutch I ordered almost 3 weeks ago isnt here... -_-
  17. #392
    did a bit of work today, got the motor on the stand, pulled the clutch and fly wheel off, called the company and they called spec, found out that my clutch should be shipping out tomorrow because Spec has had a manufacturing delay.
    I also got my oil filter base gasket changed out on the block, the current engine in the car leaks like a bitch.
    I also went ahead and put the oil filter sandwitch plate on there ready for my oil pressure gauge. I need to get around to mounting that and my boost/vac gauge.
    Then after all that I HAD to get a test fit of this on the engine..
    Im Excied to get this thing going. After i get the head on there im going to adjust the valves and get that straight, replace gaskets everywhere(im thinking of rear man seal just because), then flip the motor and pull the oil plan and get it drilled and tapped for a return. then ill be just about fully ready to drop the motor in beside the clutch and flywheel.
  18. #393
    Coming along nicely, do you plan to keep AC/PS?
  19. #394
    Calgary, AB, Canada
    I am jealous of your turboness.... I want more power!!
  20. #395
    hahaha ac and ps? I have never had that un any of rhe cars ive owned for more then a month or two.
    and hash, want a manifold? I have one from the gb I dont need.
  21. #396
    Calgary, AB, Canada
    If I still had an a20 I would take you up on that offer. Trying to find a vtec head for my b20 this next year.
  22. #397
    I always remove PS, but it's hard to go to work without a sweaty back here in Texas lol.
  23. #398
    Why would you use that mass of sprinkler system plumbing when you have a compact log manifold?
    Nice to see any progress though, ¤{}€
  24. #399
    Ahh got ya, I just got it to help the gb lol
    Shit I fell ur psin x10. No ac in Phenix az was killer. 120 outside so lije 140 in my car. .. it was BADDD
    because the ramhorn is cooler, and is externally wastegated. It prob flows smoother then the log too. Im pretty sure it would.
    but updated, crank pully bolt. Fuck it. I need to remove it so I can replace the head, timing belt, belt pully, and other random gaskets. .. how do you guys remove the pully bolt?
  25. #400
    LX User apache07x's Avatar
    Feb 2011
    1987 Honda Accord, 1988 Honda Accord Hatch LXi, 2003 Pontiac Grand Prix
    Winter Haven, FL
    how do you guys remove the pulley bolt?
    Impact wrench
  1. Tdurr's Turbo Thread!
    By Tdurr in forum Forced Induction
    Last Post: 04-02-2012, 08:56 AM
  2. Tdurr's Offical Thread
    Last Post: 04-16-2011, 12:59 AM
  3. Tdurr On New Wheels
    Last Post: 10-31-2010, 01:05 PM
  4. Tdurr's pedoccord in action
    By e30pwr in forum Classic Honda Pics & Videos
    Last Post: 03-29-2010, 03:39 PM
  5. Tdurr Comes to Savannah!
    Last Post: 04-11-2009, 07:50 AM
