Page 24 of 44 FirstFirst ... 1420212223242526272834 ... LastLast
Results 576 to 600 of 1084
Thread: Tdurr's round two!
  1. #576
    Re: Tdurr's round two!
    Thanks, I gotta go and get some new fittings for my catch can. It could be set up a whole lot better on the vc breather. But ill worry about that in due time. Right now im haveing some pretty not cool oil leaks on the head(vc and dizzy oring I think). They run down the whole block and I cant tell if thats the only leak or not :/
    But I did manage to get an aglinment today. Still -4 degrees of camber in the front, but the rear is at a 1.7. Also found out that the driver side toe adjustment is frozen/rusted to the bushing so ill have to work on getting that fixed soon.
  2. #577
    Less than 5k till the chassis it at 400k. The motor, hah, its just rolling past 2k on the freshin uo, and 85k from what I was told.
  3. #578
    welp, changed out my vc gasket and polished the letters/lines on my vc today. Also cleaned up the tranny a bit from the oil leak on the vc and/or dizzy oring. ill find out soon if the dizzy oring is bad or not. But in the process of doing all that i ended up breaking my coolant temp sensor. Gotta fix that tomorrow(i have a spare clip it just got dark) other then that car is running good. Oh also, when i went to get my aglinment we found out that the driver side toe adjustment nut/bolt is ceased to the bushing so i have -1.2 degrees of toe on ONE tire. -_- gotta source a whole new rear "sub frame" idk if that what it is called. But ill prob hit up a jy soon and order some of the LCA's from Jordan.
  4. #579
    Mar 2012
    1988 Honda Accord LX-i 2 Door Coupe 5 Speed
    Charlotte, NC
    Heat the bushing up with a torch. You will need to replace the bushing but its cheaper than a new rear frame. Same thing happened to mine. The toe bolt and nut are still available through Honda (or junkyard)
  5. #580
    i tired that along with the alignment guy. I swear this car was in a flood or mudded at some point in its life
  6. #581
    Mar 2012
    Charlotte, NC
    So torch the bolt off (cut through the bushing if necessary, may need to replace the control arm though)
  7. #582
    Like i said, ill fix it once i get the cheddas LCA's. and thats a few weeks out at best
    also got bored and found this. Client Validation
    link for whenever i need to replace my rotors
  8. #583
    I want that front crossmember in my car now!
  9. #584
    Yea, you gain ALOTT of space when you put it in. I do plan on taking a few pics today to send explicit speed. Where the lca bolt up, the part there is a bit tall. To install it I had to pull the lca out, then tighen the bolts, then hook the lca back up. Then it looked like if your car wantlsnt lowered as much as me, your axel would rub on the bolt head. I will try and get some solid pictures today tho.
  10. #585
    Yes indeed. It's looking very tight.
  11. #586
    well for those who dont know, i dropped a bolt in my transmission when i was swapping out the speed sensor... ruined my day yesterday. it fell in the hold for the speed sensor, and i just heard splash tink tink.... so much range ensued. but after some cursing, prayers, and a LOT of luck with a flexible magnet i managed to get this.
    it took me like 5 hours to get that out of there. but i was about to get ready to pull the transmission to get it out.
    BUTTT what i set off to do yesterday was change out the transmission fluid with this:
    had a grind in 2n gear, and got tired of it. No grind now but i did find this on my fancy pants drain plug.
    yea pretty nasty if u ask me.
    ALso got some in the air photos of the traction bar. to show the tight fit of the lca bolts.
    Driver side
    Pass side
    the bolts were so long they smacked the axel and shock fork.
    And random pic time, saw this thing at work.
    had a built SRT4 motor in it. guy said it was making 740ish to the wheels. talk about a crazy swap.
  12. #587
    i Did a small bit of work on the car this morning. I replaced my ECT plug. one of the wires broke off and so ecu wasnt getting any signal. I also replaced my dizzy cap(again). I now have a back up! I thought it fit the color theme of the bay. You will see the pics. and I snapped a few close up of the vc letters. I didnt think to mask anything off cuz it was so spurr of the moment random that i polished them. anyways enough text, here are some pics!
  13. #588
    Purple cap looks game (Y)
    :ninja:
  15. #590
    Welp for those of you who dont know, I did this the other day.
    Been needing a reason to beat on this motor a bit more. Lol
  16. #591
    The game
    Go home. Ur game.
  18. #593
    Post a wot vid already
    What kinda vid u want? Im off today and tomorrow lol
  20. #595
    well since you have never responded i have something for you.
    found this in my door panel.
    kept hearing a clicking and my batt kept dying randomly. so i did this after super gluing the cap back on.
    there is also all of this crap behind all panels. I swear this car was flooded man. anyone have a carfax??
    also got you a lil video too.
    https://www.youtube.com/watch?v=BLe-...ature=youtu.be
  21. #596
    That is the fix for the parasitic battery drain in coupes. It's about the most elegant solution I've found.
  22. #597
    Yep, same here.
  23. #598
    hey im okay with it as long as my little battery doesnt have to keep getting jumped. its like 4 months old and has died like 5-10 times thanks to that crap.
  24. #599
    Got stuck ib the driveway today leaving to get lunch. Had to get 2 ppl to push me haha
  25. #600
    LX User JohnBoy's Avatar
    Nov 2008
    87/honda lxi accord, 04 xterra, 87 f-150, 93 f-350, 75 camaro, 01 gsx-r
    spokane, WA
    now that's a short ram
  1. Tdurr's Turbo Thread!
    By Tdurr in forum Forced Induction
    Last Post: 04-02-2012, 08:56 AM
  2. Tdurr's Offical Thread
    Last Post: 04-16-2011, 12:59 AM
  3. Tdurr On New Wheels
    Last Post: 10-31-2010, 01:05 PM
  4. Tdurr's pedoccord in action
    By e30pwr in forum Classic Honda Pics & Videos
    Last Post: 03-29-2010, 03:39 PM
  5. Tdurr Comes to Savannah!
    Last Post: 04-11-2009, 07:50 AM
