that smoldering pile right at the end was great.
It was cool
un-motivated!
3GR
So now that it's he need a answer to the ultimate question. What was the damage(total cost)
Damn street racers!!
I havent even tried doing a burnout in my car for years
Ricer!!
You should change your name to slow rocket. Lol
I got a kick out of that!
un-motivated!
3GR
I found some of the old HT post we can always try the last know email and see if he's still around. http://honda-tech.com/drag-racing-36...rward-1366837/
i wonder what the next weakest link is in the gearbox now the diff is fixed.
So chedda just got a 3geez so I'm sure the A2B kit and will be done at some point.
does it leak fluid out of the axel seal?
If f shorten the lca it would do the same thing as longer axels be bringing the knuckle closer
Pop it back in place making 100% sure it's seated. If it pops out again then you probably need to replace the little keeper rings on the axle.
un-motivated!
3GR
I popped it back in friday, but when i tightened the axel nut it pulled all the slack out the axle so it pretty much was preloaded to pop out. Went about a mile chwcked it and it popped out a half inch again. So either this axel is somehow too short, or my hub isnt pressed in all the way
Hum
