Results 1 to 10 of 10
Thread: Misfire after tune up, what did I do wrong?
    Jun 2010
    88 accord lxi coupe 5 speed
    San Diego
    Ok I finally got to replacing the spark plugs, wires, ignition rotor and cap. But when I replaced the ignition rotor the new one I got was not as snug tight as the old one. Anyways the first one I bought did not work and the replacement I got started to make my car sound/feel like it was misfiring. Anyways I was going to head to pepboys and get another replacement since the last two came from autozone. Anyone have any thoughts on this subject? Do I have to use a lube/glue to get the ignition rotor to fit right?
    Re: Misfire after tune up, what did I do wrong?
    three things come to mind:
    Always buy cap and rotor in matched sets, same brand.
    Sometimes new wires can be defective or damaged during installation.
    What kind of plugs did you get? Im kinda wary of the tiny electrode denso, stick with NGK V groove.
    LX User vteckiller's Avatar
    Oct 2011
    1989 Honda Accord LX-I
    OR
    Quote Originally Posted by BrokenBone View Post
    Lol.. are you sure you are even buying the right parts..
    LIFE IS SHORT, DRAG IT OUT!
    2.0Si User ShyBoyCA6's Avatar
    Oct 2009
    89 Honda Accord Coupe
    most likely you have mix the firing order...or messed up wires.
    i would get the NGK's spark plugs and wires. cap and rotor should be the same.
    Nov 2002
    Ridin Dirty in New York
    Quote Originally Posted by ShyBoyCA6 View Post
    agreed. If you have to use glue to get the rotor to work its def not the right rotor...
    Jun 2010
    San Diego
    I got all the right parts, the car ran good for about 10 miles before it started misfiring. Anyways I drove about 20 miles today and it did just fine. I was just concerened that the rotor did not grip properly because the old one I had to give it a hard tug to get it off.
    Anyways how do I get to the air filter in the bumper
    Oct 2009
    By Searching and reading grasshopper
    LXi User CzEcHy's Avatar
    Jul 2008
    89 Accord LXI
    Gulf Breeze, Florida
    Air filter in bumper? This is news to me, do you have a CAI?
    Oct 2011
    OR
    Quote Originally Posted by CzEcHy View Post
    Probably talking about the tube the stock one goes to that is next to the battery.. it sticks up out the top of the fender well in the engine bay its stock rubber.. ?dunno?
    SEi User obdriver6's Avatar
    Nov 2008
    1989 Accord LX-I Coupe
    Las Vegas, NV
    Unless you have a CAI, the air filter is behind the intake manifold. If you do have a CAI then you can remove the bumper for easy access.
    1989 Honda Accord LX-I 300K+
    Build Thread
  1. 85 accord with carb lean misfire
    By Taylor Smith in forum 2geez Tech & Performance
    Last Post: 03-28-2014, 08:03 PM
  2. Misfire under load...
    By Jasonf860 in forum Carburetor Tech
    Last Post: 04-11-2007, 03:59 AM
  3. Misfire
    By HondaBoy in forum 3geez Accords
    Last Post: 01-13-2007, 08:13 PM
  4. Emission Problems & Possible Misfire
    By En-g in forum 3geez Accords
    Last Post: 08-28-2006, 05:36 PM
  5. Misfire Problem....Need Expert Help
    By 01RomanSS in forum 3geez Accords
    Last Post: 04-01-2004, 06:14 PM
