Results 1 to 15 of 15
Thread: Tach works when it wants...
    I looked a few different times on here for tach problems and saw one of 3 suggestions. They say it's either a dizzy going out (car doesn't misfire at all), or bad ground(not sure what ground to even look for), or a bad cluster.
    Any ideas? It will sometimes work for a few hours then stop for 10min or a few days. There isn't any pattern behind it at all.
    Re: Tach works when it wants...
    try swapping the coil, there is an internal resistor built into it for the tach signal, the dizzy directly fires the coil, then the resistor is between the negative terminal of the coil and the output on the blue wire
    It's your ICM.
    Icm?
    89T's Avatar
    Apr 2004
    listen to your distributor. If it sounds like there is a small rock kicking around in it, replace the whole thing. If it sounds good change the coil
    the hatch was like that when I first got it, turned out to be a bad coil
    Well since it's the coil I'm just not gonna bother. Gonna be going obd1 with a internal coil hopefully by Feb so it should fix it then. thanks formthe quick replies tho.
    My tach settled down when I replaced the ICM. I had the random tach hop though. It was working otherwise.
    LXi User Buzo's Avatar
    Dec 2010
    North of Mexico
    This is the fix for your tacho problem. A 2.2 K ohms resistor in the wires shown in the picture.
    Power is nothing without control
    Quote Originally Posted by Buzo View Post
    but if you do that it's going to increase the resistance to double what it should be, the internal one is part of the coil and inaccessible, I suspect it's failing due to years of heat exposure, there is a lot of heat inside of that coil
    Dec 2010
    North of Mexico
    If you are concerned with the parallel resistor value, you still can cut the blue wire between the resistor and the coil terminal. But it's not needed.
    the resistor is inside of the coil. it's part of the assembly.
    learn something every day. had no idea there was a resistor there.
    Dec 2010
    North of Mexico
    I meant cutting the wire between the terminal B of the coil and the external resistor.
    Typically this tacho signal coming out of the coil is used for signal only, so there will be almost no current draw from this wire. That's why 2.2k (with the internal coil resistor only) or 1.1k (with the parallel resistor added) doesn't matter to the tachometer in the dashboard and other devices that use this signal in the car. Also, even though I know it probes nothing, I used this parallel resistor in my car for 8 months with no issues.
  1. MSD tach adapter driving stock tach
    Last Post: 05-11-2008, 09:57 PM
  2. well nothing works now
    By levon2008 in forum 3geez Accords
    Last Post: 03-21-2008, 11:10 PM
  3. My God it Works and the Ac to
    By TWOLOUDNPROUD in forum Classic Honda Pics & Videos
    Last Post: 05-24-2006, 05:37 AM
  4. do you think this method works
    By 89AccordLvr in forum Interior & Exterior Care
    Last Post: 03-08-2003, 11:54 PM
  5. Hmm, A/C works now but not much
    Last Post: 09-21-2002, 09:31 AM
