My oil pan is leaking, the issue can be caused by the
stupid guy who changed oil ? What I can do? Replace the Pan forcefully?
is it may be useful change the gasket? thank you cheers
lorenzo
Honda accord aerodeck III gen 1987 efi
lorenzo
If it's leaking from the drain plug area then tighten it. make sure it has a drain plug gasket. when that is done, clean around the oil pan with a semi clean rag to see if it still leaking. If there is a leak then its time to replace the oil pan gasket.
Take it back to whoever changed the oil and make him fix it.
Where is it leaking from and how much?
it's from the oil pan, just a little bit. nothing you can see or hear. The point is that maybe there's too much oil. I mean
checking the dipstick the level is over the upper mark. Can be a problem?
May be the stupid guy has not drained the old oil.
IF you decide to replace the oil pan gasket with it leaking.. Use OEM oil pan gasket & new down-pipe exhaust manifold gasket..
