not too sure if the color of the wires are the same as the later model hondas but if they are, the wires coming from the car are:
Code:
function ............................color/stripe
12v constant .....................white/yellow
12v accesory .....................yellow/red
12v ground ........................black
dimmer (lights) ...................red/black
Left front (+) .................... Blue/Green
Left front (-) .................... Grey/Black
Right front (+) .................. Red/Green
Right front (-) .................. Brown/Black
Left rear (+) ..................... Blue/Yellow
Left rear (-) ..................... Grey/White
Right rear (+) ................... Red/Yellow
Right rear (-) ................... Brown/White
and from your head unit will most likely be like this:
Code:
Memory (+12v Constant) Yellow
Ignition (+12v Switched) Red
Ground (-) Black
Power Antenna Blue
Amplifier Turn-on Blue/White
Right Front (+) Gray
Right Front (-) Gray/Black
Left Front (+) White
Left Front (-) White/Black
Right Rear (+) Violet
Right Rear (-) Violet/Black
Left Rear (+) Green
Left Rear (-) Green/Black
just match those up and you should be good as gold. I would also recommend grounding the stereo straight to the car
