Results 1 to 10 of 10
Thread: blower motor stop working
    bridgewater.NS Canada
    Exclamation blower motor stop working
    Ok so I went out to start my car today because the battery is weak.It's been -25 for a couple of days,so car starts up but when I turned on defrost nothing happens.I turned it on full and nothing,switch to heat,vent nothing but can hear the buttons functioning .Checked fuse 22 under hood and 12 and 14 under dash and they were good.Why would this happen like this since yesterday.If it's the resister or motor I can't fix it in this cold,but won't be able to drive it either.
    Re: blower motor stop working
    Take a dead-blow hammer or screwdriver handle or hair brush or something and give the blower motor a good solid crack on the motor housing. You don’t want to dent it, just jar it good. If it starts working, it’s time for a new motor.
    SEi User Hauntd ca3's Avatar
    Sep 2007
    1988 ca3 si exclusive
    new zealand
    blower motors are famous for filling up with water and crap in general.
    and at -25 degrees, any water will have frozen solid and seized it up good.
    any hoo, they arnt hard to change if its shagged
    SEi User obdriver6's Avatar
    Nov 2008
    1989 Accord LX-I Coupe
    Las Vegas, NV
    Sound like the blower motor. If it was the resistor, it would work on high.
    1989 Honda Accord LX-I 300K+
    Build Thread
    Dec 2010
    87 Honda Accord LX-i 5sp sedan 87 Honda Accord LX-i 5sp hatch
    Jack, Alabama
    If it doesn't work, check to see if you have power at the blower and also check to see if there's ground. It should have power as long as the key is in the run position. If you have both power and ground at the plug, than its the motor. Let me know if its a power or ground problem and we can go from there.
    Well went out today to start the car,I turned on the blower and it worked.But notice not much coming out unless it was on high,hope it stays working cause it's to cold to work on it.I guess it could have been froze,but maybe it's the resistor.
    Dec 2010
    Jack, Alabama
    I've kinda been having the same problem with my blower, everytime I get a chance to se what's wrong with it, it works.
    LXi User ecogabriel's Avatar
    Apr 2008
    Atlanta, GA
    I am not familiar on how similar the heating system is in the Accord compared to the 5G civic but when I removed the blower I found a good share of leaves packing the insides of the blower turbine. Once removed, the airflow improved a bit. I still have a good deal of "lint" hanging on the A/C evaporator so my airflow in that car is still "asthmatic", but it is definitely better than before.
    If the resistor were the problem it should still work on high though.
    LX User JJ'sAccord's Avatar
    Dec 2016
    1989 honda accord LXI
    South Carolina
    does anyone know how to get the knobs off the climate control without destroying them? There has to be a trick that i need to know.
    There is no trick. The ends of the metal control rods are barbed. The only way to remove the knobs is to pull them off, which will require a great deal of force to accomplish. When they come off, some material will pull out the backs of the knobs. So basically, you'll have to break them. Fortunately, they will still work well enough when you put them back on.
  1. Turn signals stop working when it gets hot outside.
    By thooper41 in forum 3geez Accords
    Last Post: 09-14-2009, 12:18 PM
  2. Blower motor not working on medium-high setting
    By nfs480 in forum 3geez Accords
    Last Post: 05-04-2008, 06:56 PM
  3. Blower Motor Problem
    By azazel_18_2 in forum 3geez Accords
    Last Post: 07-12-2007, 06:53 AM
  4. HVAC blower motor
    By wknox in forum 3geez Accords
    Last Post: 01-11-2005, 07:40 AM
  5. speedometer stop working!!!
    By rleyba in forum Classic Honda Community Chat
    Last Post: 06-22-2004, 07:11 AM
