Results 1 to 13 of 13
Thread: Smoking Brakes
    Jan 2012
    Unhappy Smoking Brakes
    89 Accord LX
    I just change my brake pads and my passenger side brakes starting smoking when I starting driving on the highway.
    LXi User RAZR's Avatar
    May 2010
    1986 accord LXI
    Chicago Il
    Re: Smoking Brakes
    Did you replace the rotor?
    Jan 2012
    Re: Smoking Brakes
    No I did not replace the rotor...
    May 2010
    1986 accord LXI
    Chicago Il
    Re: Smoking Brakes
    Does smoke all the time?
    And why would you only replace one side pads?
    Jan 2012
    Re: Smoking Brakes
    I replaced the driver and passenger side brake pads. I came home through at a maximum speed of 45 mph and it did not smoke.
    May 2010
    1986 accord LXI
    Chicago Il
    Re: Smoking Brakes
    Quote Originally Posted by HONDAMAN222 View Post
    It may have been something on the new pads that burned off when u drove it.
    Re: Smoking Brakes
    Possible that the caliper stuck closed when you pushed it in the put the new brake pads on. Other thing I could think of is you didnt clean all the greasy fingerprints off the rotor.
    Big thing to look for is excessive heat. If that caliper is stuck it will over heat in a few miles.
    Jan 2012
    Re: Smoking Brakes
    It was the caliper.....however, now my brake lights stay on.
    Re: Smoking Brakes
    low brake fluid or your e brake is on.
    Jan 2012
    Re: Smoking Brakes
    i have the e brake on because its a manual & the reservoir is full.
    Re: Smoking Brakes
    Sorry I read that the brake light on the dash was on.
    There is a push button switch mounted top of the brake pedal (underdash) that triggers the brake lights.
    Re: Smoking Brakes
    This.
    and this.
    SEi User Hauntd ca3's Avatar
    Sep 2007
    1988 ca3 si exclusive
    new zealand
    Re: Smoking Brakes
    sounds lie a classic case of sticky slides to me
  1. Big Brakes and Addco rear sway bar on sei brakes
    By EricW in forum Classic Honda Pics & Videos
    Last Post: 10-01-2007, 01:13 PM
  2. Smoking, in the bad way
    By SmokeyTheBear in forum 3geez Accords
    Last Post: 08-27-2006, 11:43 AM
  3. Smoking from motor
    By sweetdang in forum 3geez Accords
    Last Post: 02-06-2006, 05:33 AM
  4. Smoking at WOT
    Last Post: 06-26-2005, 09:26 PM
  5. Switching carb brakes to EFi brakes...
    By Hash_man_Se_i in forum Suspension/Wheels/Tires/Brakes
    Last Post: 02-21-2005, 04:09 PM
