Results 26 to 50 of 53
Thread: Where do I find coilovers for 1g Accord GUISE?!?!
    LX User rustlude87's Avatar
    1987 Honda Prelude Si
    Re: Where do I find coilovers for 1g Accord GUISE?!?!
    OMG this is purely amazing, you sir are a genius!
    Feb 2010
    cant wait for the new rear setting
    3Geez Veteran gfrg88's Avatar
    1986 Honda Prelude 2.0Si-T
    A Mile High.
    god. I always come in here and drool over your car.
    In for more pics!!
    -Gio
    My E85 Turbo Build
    5280FEST
    In for more pics!!
    Heres your PICS!
    LX User Honda Man's Avatar
    Jul 2011
    86 LX-i Hatch
    San Jose, California
    Pics of your car never get old.. no matter how many times we've seen them!! I should start looking around for a nice clean 1st gen!!
    X2 DEF!
    So let's say I wanted to import one of these sexy 1st gens (RHD FTW) to the US. How much would it cost to at least buy a beatup one?
    Low loud lovin it!
    ~~~~~~~IG @the_boso_3g~~~~~~~
    Quote Originally Posted by Honda Man View Post
    X2 DEF!
    More than you can afford pal...
    LXi User hondalude86's Avatar
    1986/Honda/prelude si
    Denver Colorado
    Dude, im assuming this is how far this car has come, amazing!
  8. #33
    Jul 2011
    86 LX-i Hatch
    Hmmm.....smaoke em'.....
    Haha nice. Seriously though, I've always been so jelly of your car and I want one really bad
    Low loud lovin it!
  9. #34
    I have no idea how much they gonna be haha sorry. Trade me with a real LHD USDM 1g? :p
    Anyway so using the stock 1g strut mounts appears to be a fail idea since its been making a lot of weird noises and the springs doesnt sit properly on the top perch. My strut bearings are failing anyway so I figured, why not make the stock Evo mounts to fit?
    Check out my super accurate method of making a template for the Evo's mount
    New hole drilled on the strut tower
    IT FITS!!!11
    I'm gonna add a plate under the mounts so they would fit between the plates and the strut towers. I'll get pics of that later
    A lot shorter now
    Compared to this:
    Does it work? Yes. A LOT better since the bearings in these mounts are much superior than the lame ass needle bearings on the stock 1g mounts. Steering feels so much lighter and a lot better now. The noises are gone. And I actually mounted the passenger side mount further back to compensate for my screwed up caster from the tweaked frame (N) But hey it drives straight and better now. My 'eyelignment' seems to work just fine :p
    I'll keep an eye on them and see if mounting them like this is gonna affect anything. I doubt that it would though considering the Evos have them mounted the same way but like I said, I'll make a sandwich plate between the mounts and the strut towers or get the old holes welded shut or something.
    Also, car is about half inch lower now. Sorry I just have to :p
    Jul 2011
    86 LX-i Hatch
    Alright I'm going to take you up on that so when I find one I'm shipping it to you with a quickness. carzy stuff with the coilovers. You made it look so easy to do man. Hella good work....now fix the header problem so you can SLAM It!
    Low loud lovin it!
  11. #36
    Poor fender
    damn get some more caster boy
  13. #38
    Jul 2011
    86 LX-i Hatch
    Dam that looks a lot beter man. I'm jelous. id say do a pic of the side of the car to show how flush it is and how the wheel stick out. that is some badassness right there!
    Low loud lovin it!
  14. #39
    Denver Colorado
    dude, this looks great! very genious! (Y)
  15. #40
    DX User Nicktorius's Avatar
    Dec 2011
    '84 Accord Hatchback
    Tacoma, WA
    Looks great... those tires are too beefy though!
    1984 Accord Hatchback
    2005 Mazdaspeed MX-5
    2007 Mazda 3
  16. #41
    SEi User obdriver6's Avatar
    Nov 2008
    1989 Accord LX-I Coupe
    Las Vegas, NV
    YES MOAR CASTER!!!... looks good btw!
    edit: I hella space out, yeah I meant camber!
    1989 Honda Accord LX-I 300K+
    Build Thread
  17. #42
    Caster wut?
    Denver Colorado
    I think what you heed is more camber! Its what tilts the tires inwards
  19. #44
    Yeah I figured haha. Funny how they mentioned that. My caster settings are messed up on both sides from the tweaked frame (N) But I've compensated the difference with moving the strut mount back so it would be parallel with both sides. (My passenger strut tower, crossmember mounting points as well as the wheel has moved back about an inch compared to the driver's side.)
    Drives straight and fine now so I guess I can't complain.
    LX User PDXAccord79's Avatar
    Aug 2010
    79 Accord 1.8L CVCC 5-Speed
    Portland, OR
    You should try and roll those fenders with a bat or metal pipe. It should flare them out a bit in the process.
    What year Evo are these off of? This is very temping to do to mine now that I know that the strut mount works.
  21. #46
    i meant caster. wheel is way too far back in the guard for my likings :P
  22. #47
    Denver Colorado
    caster really is just the axis that the turning wheel pivots on... I do know that to adjust the axis most cars really force the lower control arm back or deflect from the "zero" point. But in this case he would be heavy positive therefore needing less positive caster. Remember, you can't have negative caster (although it seems like you could) but when you look at his wheel turned out, it doesn't seem to have that much caster...hmmm,
    there is an inherient increase of caster when lowing a vehicle, and its possible that it isn't possible to change this on his car, since its macpherson strut, or at least for it to look normal in the fender wheel, but really i think this is what he was trying to correct with the modification of the top hat placement for the strut. Without adjustable tophats i think he is stuck with what he has...
    fwew, thinking about this whole thing makes my head hurt...I guess most of what i just talked about really only applies to my prelude...i think i have over generalized here...sorry if what i posted is completely wrong... Some one shed some light on this?
    One thing is for sure though, I love me some positive caster, makes my car turn better, but damn hard to keep going straight...
  23. #48
    This is pretty much what happened to my crossmembers. And no, they are not bent. I had both of them replaced and my frame was bent (N)
    Hada compensate for the difference by bringing the right wheel back about 1cm or so and the left wheel up front about 1cm as well so they would be parallel to each other by adjusting the radius rod. That and the left side strut tower is bent too (moved about 1.5cm back) so right now my caster and possibly camber too is all messed up.
    What I did was, I mounted the left side strut mount about 1cm further up front and the drivers side about 5mm back so they would be equal with both sides. Funny how it drives straight/fine now even with my 'eye'lignment done :p
    I really would love to see what its like on the alignment rack tho. My dad told me to not get the frame straightened back as there are cases with older cars like this with hidden rust spots basically having the whole front end ripped off haha. These band aid fixes works as a dd, drives fine, it goes straight. steers fine even with the unequal caster o.O Not sure how it would work on the track but then I don't plan on doing that anytime soon, at least not with this car
    BTW its off an early 90s lancer/Evos. Evo III to be exact, I'm not sure of the year?
    edit: its early in the morning so I'm sorry if I don't make any sense at all in this reply kthx
    DX User EM1 ADCT's Avatar
    Aug 2010
    '80 Honda Prelude XR
    Virginia
    I read this and I want to hug you......in a none homo kinda way. haha. U sir are a genius!
    I just located all four Koni Insertable Struts for my ludes housings and I think I'm going to keep the cut springs but hope for a better ride quality with the Koni's. The difference in the cylinder size is amazing compared the preludes size.
    My Project Site - WWW.G1PRELUDES.COM
    Current Ride - 1980 Honda Prelude XR
    SN Fanatic
  25. #50
    I lol'd. Can't wait to see yours slammed once again!
  1. so 90-97 accord coilovers fit perfect?
    By Rendon LX-i in forum Suspension/Wheels/Tires/Brakes
    Last Post: 03-08-2015, 09:14 AM
  2. Brand new Coilovers for the accord
    By HondaSi88 in forum For Sale
    Last Post: 10-05-2011, 06:49 AM
  3. ebay find coilovers are they worth it????
    By buds302 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 02-03-2005, 12:20 PM
  4. Help me find Coilovers for my 88 Hatch!!!
    By 3GHatch in forum Suspension/Wheels/Tires/Brakes
    Last Post: 08-11-2003, 06:47 AM
  5. Will 90 Accord Coilovers work ?
    By GreenMachine in forum Suspension/Wheels/Tires/Brakes
    Last Post: 07-10-2002, 05:37 PM
