Whats up 3geez. Let me first start off by saying, I should know better than to think this would be an easy job. What I thought would be a quick 15 minute project has turned into a screaming match between me, the car, and every tool I can hurl at the garage wall.
That being said, I went to change my fuel filter last night. Disconnected negative battery terminal, relieved fuel pressure, brick wall. Tried to remove the OUT connection on the fuel filter, and it is FROZEN SOLID. WILL not budge. Soak in WD-40, rinse, repeat, nothing. OK, no problem, I have an impact at home (Was at my sisters, she has a garage.) So lets just put the bolt back in so that I can drive it home. Do that, try to start it back up, Nothing. Fuel spraying everywhere, from where the rubber meets the steel on the IN line to the filter. Heres what I'm talking about:
The line in the foreground. Should be easy to get off with a 14mm Line wrench, right? Which way should it turn, Clockwise, facing me or counter-clockwise? REALLY don't want to break this, seeing as how I've alreaady broken one line... I'm thining that this line may have already been broken, causing my poor gas mileage (22mpg's right now...) but it wasn't this evident before i got to tinkering.
Changing a fuel filter should NOT be this difficult damnit! I'm praying to 3geezus!
