Results 1 to 13 of 13
Thread: Chirping sound coming from engine somewhere.
    Jan 2012
    as the title states there's a chirping sound coming from my engine somewhere...it get's louder and faster when I step on the gas. I think my valves need an adjustment, but I'm not sure. Any ideas? thanks.
    Re: Chirping sound coming from engine somewhere.
    check for parakeets
    DX User PENN's Avatar
    Mar 2010
    89 lxi
    cedartown
    mine did that too. evry time i pess the gas especialy in one paricular place it would chirp or make a whistle sound. found that it was due to the air mixture screw had been turned.
    Jan 2012
    So it turns out I had a parakeet nest in my engine bay haha I'll check the air mixture screw, I have been having problems with my air/fuel mixture anyway.
    I would suspect the water pump or timing belt tensioner.
    SEi User obdriver6's Avatar
    Nov 2008
    1989 Accord LX-I Coupe
    Las Vegas, NV
    ^^ This or the alternator bearings are going out.
    1989 Honda Accord LX-I 300K+
    Build Thread
    Jan 2012
    alright, I think the timing belt is due for a change, I have no idea when the last time it was changed was. my car needs a lot of little stuff.
    1st order of business is inspect/change your accessory belts, make sure you do not have any p/s fluid leaking on them. A tell-tale sign of oil leaking on your belts is a dirty streak on the underside of your hood over the belts.
    if you are 100% sure your accessory belts are not squeaking then it could be a bearing failure in your water pump, alternator, t/b tensioner, or p/s pump or even an internal engine bearing failure.
    Throwout bearings on 5-speed cars can do this noise, I've even heard auto trans cars make this noise if their fluid is low.
    Does it make this noise in neutral or only in gear?
    Eric
    Jan 2012
    I checked all the belts, and listened really hard but couldn't figure it out. I ran seafoam through my system last night and it stopped.
    Mar 2012
    89 Accord lxi
    Reading, PA
    I have a similar problems. Mine only does this once in awhile, but i get pretty bad chirping. The one time I hit a puddle and it chirped for a good 30 seconds but went away. Each time it chirps its only for a few seconds but then just goes away.
    DX User Bassmastry101's Avatar
    Oct 2008
    '88 Accord DX - '86 4Runner - '92 S10
    Quote Originally Posted by HelenKellerrr View Post
    Check all your belts
    Mar 2012
    89 Accord lxi
    Reading, PA
    They all look good, but i think the one needs a little bit of tightening.
    thatll do it
  1. Rattling/Knocking sound coming from engine...
    By mrma5b in forum EFI Tech
    Last Post: 04-10-2011, 03:40 PM
  2. Sound coming from front end!
    By kwmowery in forum 3geez Accords
    Last Post: 09-09-2009, 08:31 PM
  3. clunk sound coming from front of car!!!
    By gfrg88 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 10-18-2006, 07:40 PM
  4. Smoke Coming From Engine A Muffler
    By ADAN619 in forum 3geez Accords
    Last Post: 09-20-2005, 12:38 PM
  5. chirping sound
    Last Post: 02-10-2003, 06:58 PM
