2ndGenGuy
Most audio setups are pretty basic. All you need is constant power, switched power (when you turn the key on), ground, and your speaker outputs. The car should have all of these wired up to the stock stereo, and hooking those up to an aftermarket deck should be a breeze.
If you think you might be having fuse problems, go to the store and buy a GRIP of fuses and replace ALL of them! I found that after so many years, the fuses deteriorate, and they lose contact inside with the end caps. I had lots of weird electrical issues that pretty much all went away when I replaced the fuses.
