So I found a head off of an 80 that matches mine so the rebuild from goes back and I find a shop to rebuild this one. Issue somewhat resolved!
Now I'm having an issue with the rocker assembly. The main rocker arm rod slid right out and all off the rockers and parts slid right off. However the auxiliary wouldn't slide out of one of the end pieces and some of the rockers were frozen in place. I managed to get it out of the cam holder with a hammer and a punch but that appears to have mushroomed the ends of the rod and I now can't slide the remaining aux rockers off!!
I have a new rocker assembly so I can try this again but should I even bother? I don't want to screw this up again and can get it to a machine shop if I need to.
Also thanks for all the help so far. Here's some progress:
Cleaned, painted and ready for install:
Engine so far. 2 of 4 pistons in:
Thanks again for all the help.
