Results 1 to 17 of 17
Thread: CV Axle came loose
    Jul 2009
    88/Honda/LXi
    Arlington, TX
    CV Axle came loose
    Hi All. I have an 88 Lxi. Last week I replaced the lower ball joints and the cv axle on the drivers side. When I took it for a test drive I got about a mile out and all of a sudden the engine started revving but I wasn't going anywhere. It felt like the clutch had gone out on me. Under the car was a puddle of the oil I had just put back into the tranny after the axle replace. I jacked it back up today to take a look and I'm pretty sure the axle popped out along with a lot of fluid.There is a gap between the transaxle seal and the axle cylinder. I have a picture but I can't paste it here since this is my first post. Is my tranny toast?? Has this happened to anyone else? I've been searching here for a while and don't see a post with this exact situation.
    thanks! --Dov
    Vanilla Sky's Avatar
    1999 Penalty Box
    Re: CV Axle came loose
    Moved this thread so it will get more exposure.
    Since you have a manual transmission, it shouldn't be dead.
    When you removed the old drive shaft, was there a clip on the end of it? If there wasn't, that clip is still in the output shaft and will need to be removed. Does the current axle have a clip on it? I've made it a habit to check for the locking clip at the store.
    That clip is normally the cause of the axle popping out, so I'd check on that first. It's a pain that you have to pull the suspension apart on that side again, but the positive thing is that nothing should be difficult to separate.
    Jul 2009
    88/Honda/LXi
    Arlington, TX
    Dangit! The old axle is long gone and I didn't think to look. That's going to be a PITA trying to determine if the old one is in there. Thanks so much for the info. I was going to go back in there tonight and try to get the thing seated but it could have been for nothing if that old clip is in there and I didn't read this post first.
    Jul 2009
    88/Honda/LXi
    Arlington, TX
    No dice. Took the left side apart again last night. Stuck my finger into the trans and did not feel an old clip or anything loose. Got the axle seated in the trans again. This time I tapped with a hammer and it really seemed to get locked in there. I couldn't pull it back out by hand. Test drove around the block several times but when I put it into reverse to go back into the garage it popped out again. I hate to do it but I yield. Towed it to my trusted mechanic today. Hopefully he has a trick for making sure it stays put. Maybe a better clip? Thanks DBMaster and Vanilla Sky for your suggestions...I REALLY thought I had it!!
    Nov 2000
    You're in unfamiliar territory for me. I have done precisely two of these; one on my Accord and one on my daughter's 99 I30. When I tapped mine in I never felt any kind of "snap" to let me know it was in. I just yanked on it to make sure it wouldn't pull out. It does sound to me like you might have a bad clip, or a worn groove inside the output shaft.
    Jul 2009
    88/Honda/LXi
    Arlington, TX
    My mechanic put a new circlip on the axle today, installed it and it popped out on him during test drive. I think he said he did it more than once and each time he did a uturn it popped out. He also suspects the inside is worn but wants to try a couple more things(one of the reasons I like this guy). Tomorrow he is going to check the size of the axle. I don't think it's short though because I compared it with the old one after I pulled it. After that he will probably order the axle he likes to install because he trusts it. If he can get that to stay in I'll probably buy it and call it a day. Not sure what happens if the inside is worn.
    SEi User Hauntd ca3's Avatar
    Sep 2007
    1988 ca3 si exclusive
    new zealand
    correct me if i'm wrong, but being a left hooker wont the drivers side axle assembly be the big long 2 piece affair with the support bracket?
    or did the a20 powered ones not have this.
    if it is the same as b20a powered accords, how on gods great green earth did the drivers side axle pop out of the trans?
    the support should hold it in place. the only joint that can pop out on that side of the car would be center tri pod joint.
    Jul 2009
    88/Honda/LXi
    Arlington, TX
    I'm not very well versed in the engine models. This was the longer of the two drive axles. There wasn't a support for the axle I removed or the replacement. It just goes directly from the hub to the transmission. It has been coming ajar about a centimeter but that's enough to disable it.
    Sep 2007
    new zealand
    must be an a series thing then.
    i'd suggest that you have been given the wrong shaft then if its popping out.
    sounds to short. most hondas have differant length shafts between auto and manual.
    Sep 2006
    1986 Accord, 1987 200SX SE
    Guerneville, Ca (Bay area)
    I know in my old civic when I would drive it, it would randomly pop out. What my case turned out being, was out of control worn motor/tranny mounts
    LX User Bluntman's Avatar
    Apr 2009
    1988 Honda Accord LXI
    Orange County Cal.
    Maybe post the part number and where you got it from and we all can check to see if it is the proper one.
    Apr 2009
    Orange County Cal.
    Another thing I do is go straight to the source and go to a axle rebuilder. Just do a search for them in your area. I have used Advanced Technology Axles in my area. Good guys and no Chinese crap. They usually will have one ready for a common swap.http://www.allthecalifornia.com/Loca...-axles_9908917
    Nov 2006
    Quote Originally Posted by Ju_S12_Turbo View Post
    This is what I would look closely at; A worn mount can cause the tranny to shift in position enough to allow room for the axle to pop out.
    LX User G. White's Avatar
    Sep 2008
    1989 Accord LXI
    Buckeye, AZ.
    I had the same problem you are having. The axle lengths are a little different between a manual trans axle and an axle for an automatic. When you were given the new axle, they might have given you the wrong one. It may seem like it is seating enough during installation but when driving it will pop out every time. PITA!!!! Reverify you have the right part #.
    LXi User ecogabriel's Avatar
    Apr 2008
    Atlanta, GA
    I was thinking about that too.
    i think you may have gotten an axle for an automatic . they are very close and easy to get mixed up. the end that goes into the trans is a slightly different length. I've gotten a mis-boxed axle before!
    Jul 2009
    88/Honda/LXi
    Arlington, TX
    Good to hear I wasn't the only one to go through this and great info about it possibly being the auto trans axle. Unfortunately I couldn't confirm anything for my mechanic because I bought both axles over 6 mos ago and didn't keep any paperwork or the boxes. Silly I know but won't make that mistake again. After it came out several times for my mechanic he installed the axle he normally does which I was happy to pay for since it worked. I got out the door for $175 total. He only charged me $50 for labor (did I mention I love this guy?!). Got a front end alignment and I've been trouble free for a good 400 miles.
  1. Left front wheel axle nut found loose
    By Buzo in forum Suspension/Wheels/Tires/Brakes
    Last Post: 04-03-2011, 07:34 PM
  2. Axle leak problem (axle will not go in the tranny)
    By Legend_master in forum 3geez Accords
    Last Post: 06-25-2006, 11:03 AM
  3. Loose Steering!!!!!
    Last Post: 03-03-2003, 05:47 PM
  4. my ass end gets a little loose
    By marc49 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 06-14-2002, 06:49 PM
  5. let loose
    By mag_pbg in forum Classic Honda Community Chat
    Last Post: 06-14-2002, 12:23 PM
