Page 2 of 2 FirstFirst 12
Results 26 to 44 of 44
Thread: 87 lxi stock car
    Feb 2012
    87 accord lxi
    cc tx
    Re: 87 lxi stock car
    [Q=JohnBoy;1090387]it sounds like your running in a road runner/ hornet class run smaller tires if your running out of rpms. adjust the camber on all four tires. really if you get caught running header and cam gears sorry but you probably wont get payed. cam you can get away with a light cam grind if they ask say its running in open loop. shave the head and block. running pulse plugs and race fuel. for now i"ll give you that.[/QUOTE]
    Ya well smaller tires is going the wrong way With the gear. Ya car is set up on all fourcorners.I also run in other v8 classes so not going to put a bunch into this one. Bad thing is I kick a lot of butt in it. . I can hide the Can gear and run the header only at certain tracks
    Feb 2012
    87 accord lxi
    cc tx
    Quote Originally Posted by JohnBoy View Post
    Ya well smaller tires is going the wrong way With the gear. Ya car is set up on all fourcorners.I also run in other b8Yj1G classes so not going to put a bunch into this one. Bad thing is I kick a lot of butt in it. . I can hide the Can gear and run the header only at certain tracks
    LX User JohnBoy's Avatar
    Nov 2008
    87/honda lxi accord, 04 xterra, 87 f-150, 93 f-350, 75 camaro, 01 gsx-r
    spokane, WA
    dude it sound like your the bad ass so i wont try to help you any more. sorry for put in info.
    I bet that civic could cheat pretty easy with a minime conversion.
    Feb 2012
    87 accord lxi
    cc tx
    Oh Well I was not being smart ass just explaining.
    Feb 2012
    87 accord lxi
    cc tx
    i need help again !! hitting rev limiter half way down straight away already have tall tires rubbing ball joints any tranny have longer second gear
    Feb 2012
    87 accord lxi
    cc tx
    need help again hittin rev limiter half way do wn straight away. Already have tall ass tires rubbing ball joints. any tranny have longer second gear? any one know of 15 inch wheels with an offset? any one have header
  8. #33
    Feb 2012
    87 accord lxi
    cc tx
  9. #34
    Feb 2012
    87 accord lxi
    cc tx
  10. #35
    Vanilla Sky's Avatar
    1999 Penalty Box
    Outside of the transmission from a carbed car and tall tires, you just need to increase your rev limit. Can you do the mods to OBD1 swap?
  11. #36
    Feb 2012
    87 accord lxi
    cc tx
    well i am not supposed to. also trying not to spend much more money on car because i also run other car in other class. if this old car wasnt such a kick ass car i would not be running it. what other advantages do i get from that swap. and whats it intail ? thanks for help
  12. #37
    Feb 2012
    87 accord lxi
    cc tx
    Quote Originally Posted by CHAR POW View Post
    hey im hooked i need obd 1 conversion help
  13. #38
    1999 Penalty Box
    You need to rewire the computer or have a harness built and add a couple of wires to the harness. Cygnus_x has adapter plates and adapter keys for an OBD1 distributor, or you can modify it yourself.
  14. #39
    Feb 2012
    87 accord lxi
    cc tx
    just installed cam from DELTA CAMS
  15. #40
    Feb 2012
    87 accord lxi
    cc tx
    anyone have header for sale ??
  16. #41
    Feb 2012
    87 accord lxi
    cc tx
    well ran first race with delta cam not to happy
  17. #42
    1999 Penalty Box
    Does it fall on its face now? Might need more fuel.
  18. #43
    Feb 2012
    87 accord lxi
    cc tx
    well ran,there specs for degree and ignition timing junk am arunning a higher volume injector setup. changed degree and ignition timing for feature .I won,but not impressed i know exhaust is issu is there. Need header. I called the guy at half time Saturday night and he did not even k.ow if they advanced valve timing like i asked
  19. #44
    Feb 2012
    87 accord lxi
    cc tx
    checked plugs. Just a little fat.Not much. I will tweak out a llittle leaner.
  1. Somewhat Stock SEi
    By CB Coupe SEi in forum Classic Honda Pics & Videos
    Last Post: 09-09-2012, 04:50 PM
  2. My (stock) '89 LX-i
    By Alexi3rdgen in forum Classic Honda Pics & Videos
    Last Post: 08-20-2006, 08:33 PM
  3. My SEI Stock
    By B16KILLA in forum Classic Honda Pics & Videos
    Last Post: 12-22-2005, 01:38 AM
  4. stock 15's
    By factorVIII in forum Suspension/Wheels/Tires/Brakes
    Last Post: 11-19-2003, 04:45 PM
  5. my stock 3G
    By 89AccordExi in forum Classic Honda Pics & Videos
    Last Post: 06-09-2003, 03:50 PM
