Results 1 to 17 of 17
Thread: Oil Pressure Question?
    LX User 91lowrider's Avatar
    Feb 2012
    85 Accord LX (carbed)
    Cleveland, GA
    I have a question for anyone that can answer. I just replaced my cam seal, crank seal and the oil pump seal. I had a lil oil leak before but now its rolling down the oil pan while running. My question is since i put the new oil pump seals would that build the pressure enough to make the oil pump out harder and faster? I have a new oil filter base gasket and dizzy o ring on the way in the mail so im hopeing that will fix the prob. I cant even take it for a test drive for the fear that im going to loose to much oil on the drive and really mess up the engine.
    LX User Bluntman's Avatar
    Apr 2009
    1988 Honda Accord LXI
    Orange County Cal.
    Re: Oil Pressure Question?
    Quote Originally Posted by 91lowrider View Post
    That base gasket is where the pressure would really be the culprit. They get real brittle over the years. It makes since that it can really leak out of the old gasket
    under pressure. I replaced mine and it along with the pan gasket etc. all as preventive maintenance. And it has no leaks. But that base mount is as the others are important. The base is under pressure as you know. Hope all works out well.
    Feb 2012
    Cleveland, GA
    Quote Originally Posted by Bluntman View Post
    So could i have been loosing that much pressure through my oil pump seals and cam and crank seals? I did notice that my crank seal was in crooked but that is a noticible difference in leaking.
    Apr 2009
    Orange County Cal.
    They are all brittle with age and heat cycling. And along with all the others the base gasket being under direct oil pressure is a big culprit. Seems like you are on the right path.
    Feb 2012
    Cleveland, GA
    How hard is it to get to the filter base and change the gasket?
    LXi User ecogabriel's Avatar
    Apr 2008
    Atlanta, GA
    Not difficult at all; there are photos somewhere in this site. Maybe getting the gasket may prove a little bit more difficult (can't recall finding it in autozone or that kind of stores... Maybe NAPA but I bought mine online)
    Apr 2009
    Orange County Cal.
    Have not done one on your model. But here is the one on my 88 LXi. Not hard and you did all that on your car so it will be a cake walk for you. https://www.3geez.com/forum/showthrea...e+mount+gasket
    Feb 2012
    Cleveland, GA
    So while im down there i should replace the oil pressure sending unit?
    Apr 2009
    Orange County Cal.
    I always do parts even if they are not related on old cars while they're are already out. Preventative maintenance is always wise. Just a cheap part it won't hurt.
    Feb 2012
    Cleveland, GA
    Is there anything else i should do while down there? Im thinking i might go ahead and install a oil pressure gauge to keep track. I have heard of ppl changeing the filter base gasket and oil pressure switch and then their oil pressure light comes on out of nowhere. What is the pressure reading suppose to be at?
    Apr 2008
    Atlanta, GA
    If you are going to install a pressure gauge, do not attach a T right on top of there. First, the threads are BSP (not NPT), but more importantly, the added weight of a T plus the sensor would make the T itself more likely to crack and break. It happened to me in a car I owned.
    I am about to install a gauge so I bought an adaptor, a 90 degree elbow and flexible hose (1/8" NPT, 18 inch) to take the T right to the rear engine firewall and attach it there . I would have to add a piece of wire for the pressure sensor but I can use the hose as support for the extra wire. 18" lenght seems to be long enough for a 3G but I'll post once it is done.
    Feb 2012
    Cleveland, GA
    Now what is BSP and NPT? So i guess the oil pressure gauge doesnt bolt right up?
    Ichiban's Avatar
    North of You.
    BSP and NPT are tapered sealing pipe threads. While 1/8 Sizes of the two appear similar, they are not interchangeable. They have different thread pitches (threads per inch) different thread forms and pitch line diameters. About all they share is a 3/4 inch taper per foot on pitch line diameter. I posted a bunch of info up here somewhere a while ago about the differences.
    ICHIBAN!
    "Now, even more better!"
    Feb 2012
    Cleveland, GA
    Does anybody know what size socket our oil pressure switches are? I went to autozone to check what size a new one is but when came home to remove mine the socket was to big.
    Feb 2012
    Cleveland, GA
    Ok so i found the 15psi autometer pressure switch but it says it closes at pressures of 15 PSI and lower, and opens at 18 PSI and higher. Well if you go and buy the stock one from autozone it says its normally Closed- Opens 3-9 PSI. So if you put the autometer in wouldnt it be reverse and go off when you drop below pressure?
    Ichiban's Avatar
    North of You.
    Stock one opens above or below 3-9 psi?
    ICHIBAN!
    Feb 2012
    Cleveland, GA
    Quote Originally Posted by Ichiban View Post
    The stock opens once the psi drops below 9.
  1. Tire Pressure Question
    By import racer in forum Classic Honda Community Chat
    Last Post: 04-11-2011, 01:42 AM
  2. P/S Pressure Hose Question
    By Pico in forum 3geez Accords
    Last Post: 12-17-2008, 09:01 PM
  3. oil pressure?
    By lightbulblxi in forum 3geez Accords
    Last Post: 01-14-2004, 02:11 PM
  4. DCOE fuel pressure question
    By AccordSi in forum Performance
    Last Post: 05-03-2003, 05:55 PM
  5. a/t high pressure side vs low pressure
    Last Post: 07-12-2002, 10:01 PM
