Results 1 to 3 of 3
Thread: polyurethane sway bar bushings
    DX User PENN's Avatar
    Mar 2010
    89 lxi
    cedartown
    ok. so i decided to add poly bushings to my list of mods. so i bought a universal pack from an auto strore, but... they didnt realy fit the way i wanted. they have a step on them that is on the sway bar side that didnt fit the sway bar pocket.
    here's with the step
    so i removed them
    then i realized the hole on the sway bar for the bolt to go through was too big which would allow for movement. the holes in the bushings were .250.. or so. so i made a spacer to fit the hole which i made the same thickness as the sway bar so the bushing sit flush in the hole
    bushing in sway bar w/ bolt
    now... as it turns out witht these modifications to the bushings they turn out to be around the same lentgh as the stock ones. so the sway bar wont be twisted in a direction that is not normal function.
    old and new
    and finaly... i got some shoulder bolts that were perfect for the job. it has a shoulder that is perfectly long enough to support the bushings with out any bushing having to rest against thread, which i figure would damage the bushing sooner than desired. i also have nylock nuts to go with them so they dont fall off.
    new bolt
    next i started on the poly mounts. all i did to these is cut the ends off the bracket because they were too long and used a dremmel to make the slots closer together. then used socket head screws and modified washers to be able to get them closer to the bracket. i only have one pic that doesnt show the bracket very well but another member has done this before and posted pics of it.
    modified bracket and washers
    end links installed
    mounts installed
    SEi User obdriver6's Avatar
    Nov 2008
    1989 Accord LX-I Coupe
    Las Vegas, NV
    Re: polyurethane sway bar bushings
    Nice but you could of gotten the Prothane end links for a direct swap although they don't come with the bushings.
    1989 Honda Accord LX-I 300K+
    Build Thread
    Nov 2000
    Blast from the past. There was a Car & Driver article a number of years ago that explained in a long winded way that the terms "sway bar" and "anti-sway bar" were misnomers. The article explained that these items would more correctly be called "anti-roll bars." I prefer stabilizer bar, but whaddya gonna do?
  1. Radius rod polyurethane bushings
    By nswst8 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 08-09-2010, 10:21 AM
  2. do they make polyurethane rear sway bar link bushings?
    By frantik in forum Suspension/Wheels/Tires/Brakes
    Last Post: 06-20-2007, 07:08 PM
  3. Polyurethane bushings for sway bar
    By jeremiah0678 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 12-12-2005, 09:31 PM
  4. Replies: 41
    Last Post: 02-19-2005, 07:00 AM
  5. Free parts w/assistance in development of polyurethane bushings
    By Prothane in forum Suspension/Wheels/Tires/Brakes
    Last Post: 09-05-2003, 07:38 AM
