Results 1 to 7 of 7
Thread: Axle Replacement - How Long?
    Dec 2011
    1989 Accord LX - Carbeurated 2.0L Auto
    Kingston, Ontario
    A quick question:
    I need to replace a CV axle on the passenger side of my '89 3G auto, wondering how long this repair normally takes when doing the work yourself?
    I have access to a lift and any tools needed.
    I'll need to :
    Drain transmisson
    Disassemble and remove axle and seal
    Replace axle and seal
    Fill transmission.
    However, it looks like I'll only have from 6-10 on Friday night to complete this work as the car club here in Kingston is closing for two weeks as of Saturday, do you think four hours is enough time?
    I have never changed a CV axle before, but I have enough experience that I'm not intimidated by the task. I don't anticipate any problems with stuck bolts and such, the car is just dripping in Krown and everything was nice and easy when I did my brake pads and rotors a couple weeks ago.
    Are there any tips for performing this job?
    Thanks!
    Mar 2010
    88 lxi
    lawrenceville, GA
    Re: Axle Replacement - How Long?
    no need to drain if ur just doin axle. just take wheel off, bust suspension loose, remove axle, go ahead and replace axle seal while ur there, put in new axle, tighten up suspension and enjoy. if u have all the tools and some patience itll happen in an hour maybe 2 if its ur first time
    88 lxi:
    Dec 2011
    Kingston, Ontario
    I'm going to drain and refill anyway with Honda ATF. Transmission has no leaks as of now and works well, but I believe there is not genuine honda fluid in there.
    SEi User obdriver6's Avatar
    Nov 2008
    1989 Accord LX-I Coupe
    Las Vegas, NV
    4 hours should be more than enough. The lift will make the work a whole lot easier.
    1989 Honda Accord LX-I 300K+
    Build Thread
    2.0Si User ShyBoyCA6's Avatar
    Oct 2009
    89 Honda Accord Coupe
    Quote Originally Posted by 88lxi-shortram View Post
    better if you drain unless you want oil on the floor. which doesn't stain right away like oil. shouldn't take more than 45 mins each side. then double check before proceeding to the next step.
    Dec 2011
    Kingston, Ontario
    Figured I'd update everyone!
    The CV axle was replaced friday night with very few problems, there were not any stuck bolts to remove or anything like that. I took off the fork, broke the axle nut, popped off the lower ball joint, and hammered the old axle out of the hub. The old axle was DEFINITELY in need of replacement, the joint just flopped around loosely and there was no grease left in there.
    The only hitch I encountered was in reassembly, Carquest provided me with the wrong seal and it would not allow the new axle to seat in the transmission. After an hour of cursing and swearing I finally figured it out and put the old seal back in there, at which point the new axle slid into the transmission like it was nothing.
    As well, on a side note, after replacing the transmission fluid with Honda ATF (A synthetic replacement for Z-1 @ over 10 bucks a litre!) it seems like the car is shifting a little smoother especially at operating temperature. But, that could be my brain trying to justify the pricey fluid..
    LXi User ecogabriel's Avatar
    Apr 2008
    Atlanta, GA
    Glad you got the job done, and that you did not destroy the old seal when removing it... stupid salespeople!
    The Honda ATF would make our transmission shift smoother - that has been reported here. I still use Dexron III; our transmissions were originally designed for use with Dexron-Mercon which is written on the fill/level check cap, later replaced by Dexron II and III. Adding a transmission cooler should improve transmission's lifespan by lowering operating temperature.
  1. Replies: 4
    Last Post: 05-10-2009, 04:38 PM
  2. CV joint (and possible axle) replacement
    By slacker in forum 3geez Accords
    Last Post: 05-03-2009, 10:28 PM
  3. axle replacement.. help?
    By 1987AccordLx-i in forum 3geez Accords
    Last Post: 11-16-2008, 05:03 PM
  4. Axle replacement progress
    Last Post: 10-02-2006, 03:50 AM
  5. drive axle replacement question
    By johnwc723 in forum 3geez Accords
    Last Post: 07-21-2004, 10:07 AM
