Would it be in different places on the auto manual tranny?
Here's a pic of the bolt you need to take out
did you dig that gearbox up from under the ground lol
Lol no that's the one I just broke. I used to go mudding on my car back before I cared about the car. Managed to get it all pretty dirty.
must've went through a fair bit of mud to get it that dirty!
You have no idea.
Yeah, I think there's plenty of love for these cars around here.
Alright, so I got my transmission out by myself, carefully and slowly. I did find that bolt on top but couldn't get a long enough extension all the way down there so I just took out the cable clip (lift the rubber shroud, pull off the clip, super easy), removed the power steering lines, and took the transmission down. (BTW, if you need an extra clip let me know since I have like 3 now :P)
I tried to take out the speed sensor after that but no luck...it seems stuck in there really well, so I'm going to use the one that came with the transmission I bought.
I have one last question, and this is important - is there a difference between an 86 and an 89 transmission? Because it seems like some of the stuff doesn't want to match up with this (apparently) 1986 transmission I bought. (The guy gave me the wrong one to begin with, I brought it back and they pulled this one for me. Yes, I told them about 10 times 1989 Accord LX-i....).
Does someone know if they are the same? 86 and 89 transmissions that is.
Thanks for the help guys, you're awesome!!
I know the input shafts on some of them are different. But I think you should be able to use it if you change the pilot bearing. There are a bunch of different 5 speeds. my lxi apparently had a transmission swap before I got it cause it had a dx/lx trans in it. I was geting 34-38 mpg. Now that I have an lxi trans back in it I only get 29-33. Here's a list of the different transmissions for our cars.
https://www.3geez.com/forum/showthread.php?t=35970
Weird...why would you get better MPG with a lower model transmission? Maybe I just don't understand :P
Ok, well I'm going to go try to make it fit. You mention the pilot bearing...can you help me out here? I have no clue what to look for. Is this near the throwout bearing? Sorry, still learning and honestly never thought I'd be replacing the transmission on my DD in my driveway haha.
Worst case scenario, I got back and tell them to pull the right transmission for me.
Carbed cars have higher gearing than fi cars do. The pilot bearing is in the center of the end of the crankshaft or center of the flywheel, idk cause I never messed with it. Some of the transmissions have a bigger end on them and won't fit int the smaller pilot bearing. I'm just assuming you could get one from the parts store. I just looked in the manual but didn't see anything about it. Am I wrong on this fellas?
all of the transmissions are interchangeable, the one you want is from the second gen prelude, it has the best gearing out of all of them. you might want to leave the speed sensor in that came with the transmission, it will be geared different for the slightly different final drive ratio, the output to the speedometer head will be the same though.
I disagree. I know for a fact some of them have a different input shaft. I found one that had a much bigger end on it.
Yes a higher gear will give you better mpgs, but a lower gear will make it quicker, not necessarily faster.
right on the transmission end. the engine end is the flywheel with the pressure plate and disc bolted to it. the splines have to slide into the clutch disc splines.this is why you use the alignment tool when you bolt the pressure plate down. the entire A series use the same input shaft splines, same clutch parts, same bell housing etc.
Well I guess the one I pulled out of an 89 must have been a one of a kind because it was definitly different. Thank you for clearing that up.
Awesome...see? I'm getting this stuff.. haha
So my transmission says A2Q6 which means those dumbasses gave me, yet again, the wrong year (1986, not 89). Here's what I'm looking for - best MPG / performance combo that's going to fit straight in. I never considered putting a different model / year than stock but if it's tried and true from so many others I'll bite.As long as you guys are sure, which it sounds like...I just don't want to have any more problems!
With that in mind...from the list posted here (https://www.3geez.com/forum/showthread.php?t=35970) what would be the best one to try and find?
I'm going to head BACK to the junkyard tomorrow to get the right one. Probably tell them by code this time, you think?
Yeah I don't know either. It was for a friends car. He had an 86 and lost 3rd. I went to the jy with him to pull another one, and when we got back we spent an hour trying to get it to go back in his car.finally we compared the two and the shafts were definitly different. The end of the input shaft was almost twice as big as the one that came out of his car. We called it a night. 3 weeks later I asked him if he ever figured anything out about it, and he scrapped the car. Man I woulda bought that thing.
Yeah, if a lot of people are seeking them out, might be hard to find.
So the one I'm looking for would be the A2K5, not the D2J5 or the D2J3 right? My junkyard pulls them for you so I won't be able to see the engine. I want to be able to tell them EXACTLY what to look for because I know they'll fuck it up again if I don't.
My next choice, if the Lude isn't available, would be the E2R5 (89 LXi), and then the E2R6 (89 DX/LX) in order of preference, right? If I put the E2R6 in, I would get better fuel economy though correct?
Sorry for all the questions, want to get this right![]()
