Results 1 to 2 of 2
Thread: question about keihin carburetor
    Mar 2012
    Honda accord 1983
    Finland
    Greetings from Finland.
    I am having these idling problems that seems to be bundled with the Keihin carburetor. Accord stalls when idling if choke is off. Or if choke is off and clutch is pressed.And idle is very high, 2500rpm or even higher. Yesterday I disassembled the carburetor and cleaned some parts of it. It didn't help so I thought to order some renew kit from ebay. But those look different kind than mine. Is there some label or print somewhere on carburetor that gives the model of carburetor? The engine is 1602 cm3 and gear box is 5 speed.
    I read that people here have had similar problems caused by air leaks, fuel filters, solenoids of the carburator, head gasket, manifold gasket...
    These problems started actually before christmas, but they went away when I started to search the source. And when there was like -20 to -30 celsius degrees, it worked fine.
    Sorry band english, not my native language.
    BR
    Mika
    LX User 91lowrider's Avatar
    Feb 2012
    85 Accord LX (carbed)
    Cleveland, GA
    Re: question about keihin carburetor
    My carb has a small silver plate on the front of it stamped with numbers.
  1. Demon Carburetor Question
    By tumminello123 in forum 2geez Accords
    Last Post: 03-03-2010, 01:31 PM
  2. MODIFICATION , STOCK 2BBL KEIHIN CARBURETOR
    By s0crates82 in forum Restoration & Custom Fabrication
    Last Post: 07-23-2005, 04:39 AM
  3. [Engine & Transmission] Running Keihin 2bbl Carburetor without emissions or electronic contorls.
    By ACCORD EX in forum How To
    Last Post: 11-24-2004, 11:38 PM
  4. Keihin jetting
    By k-roy in forum Carburetor Tech
    Last Post: 03-02-2004, 01:14 AM
  5. d15b1 dual carburetor engine question
    By jayzee99lk in forum Carburetor Tech
    Last Post: 05-11-2003, 08:20 PM
