Results 1 to 4 of 4
Thread: timing belt jumped teeth/TDC?
    DX User l0l's Avatar
    Feb 2012
    1986 Accord lx 5 spd Sedan, 1999 Em1/98' spec ITR swap
    Atlanta, GA.
    Well I've got a problem! My tensioner was making an odd noise upon acceleration so i figured the t-belt was too tight. My dumbass loosened it up too much and the t belt dam near fell off and jumped a few teeth...
    No sweat so far, I have got everything off but for the life of me i can't find TDC on the crank so i have no way of lining up with the cam gear. All i see is a dot on the crank sprocket and no other marks.
    I've got the cam gear at TDC but with out being able to check the crank position correctly i have no idea if im truly at TDC. Seems like both are way off now and not lining up correctly. I hate to bend valves or anything so if anyone can got me on the right track that would be great.
    Like wtf lol...i can not find a mark for the crank on the block, crank pully, or lower t belt cover. All i see is the little circle on the sprocket.
    Sep 2009
    86 Accord LXi 5sp, 293k
    Montgomery, AL
    Re: timing belt jumped teeth/TDC?
    The TDC mark is on the flywheel. Search for the service manual from Dr. Snooz its a good one.
    '86 Accord LXi Sedan my dependable daily driver w\318k. "Why yes I do have a 3GEEE!"
    LXi User ecogabriel's Avatar
    Apr 2008
    Atlanta, GA
    x2. T mark on the flywheel. It may have skipped more than a few teeth.
    you may need to turn the engine very slowly to get to the mark. ignition timing mark and TDC are separated by 15 -20 degrees depending on application.
    Feb 2012
    Atlanta, GA.
    got everything fixed up haha..after two days and A LOT of work she's running great! Thanks guys!
  1. What happens when your Timing Belt goes?
    By Oz87Si in forum 3geez Accords
    Last Post: 03-13-2008, 04:31 AM
  2. Timing belt
    By jamsaccord in forum 3geez Accords
    Last Post: 12-14-2007, 03:54 AM
  3. I need timing belt help
    By dmitch31 in forum 3geez Accords
    Last Post: 05-30-2007, 10:40 AM
  4. Timing Belt
    By TigaMan10 in forum Classic Honda Community Chat
    Last Post: 03-12-2004, 12:12 PM
  5. timing belt teeth #?
    By shepherd79 in forum 3geez Accords
    Last Post: 09-15-2003, 11:21 AM
