Well I've got a problem! My tensioner was making an odd noise upon acceleration so i figured the t-belt was too tight. My dumbass loosened it up too much and the t belt dam near fell off and jumped a few teeth...
No sweat so far, I have got everything off but for the life of me i can't find TDC on the crank so i have no way of lining up with the cam gear. All i see is a dot on the crank sprocket and no other marks.
I've got the cam gear at TDC but with out being able to check the crank position correctly i have no idea if im truly at TDC. Seems like both are way off now and not lining up correctly. I hate to bend valves or anything so if anyone can got me on the right track that would be great.
Like wtf lol...i can not find a mark for the crank on the block, crank pully, or lower t belt cover. All i see is the little circle on the sprocket.
