Results 1 to 11 of 11
Thread: TDC Sensor
    snoopyloopy's Avatar
    Killa Cali
    TDC Sensor
    08 LED FLASH(s) 85-98 Accord
    TDC Sensor (Top Dead Center)
    defective circuit or unplugged / defective sensor
    Alright gentlemen, I've decided that it's high time I get this car finished up since it hasn't been driven since July (except once when I brought it home). The title of this thread is the code I'm getting. For the longest, I wasn't even getting any codes. The engine would just be cranking with no sign of life until finally I got a CEL with that information. So now the big questions: where is the TDC sensor located and what would be some possible avenues to explore in attempting to bring it back?
    Jun 2010
    89 Accord DX
    Re: TDC Sensor
    TDC sensor is in the distributor, I'd say its got a dead distributor...
    1989 Accord DX converted to EFI and OBD1 on P06 Ecu using Hondarulez RTP
    Blaster 2 Coil, Pacesetter Headers, 4G Injectors, 4G Alternator, Skunk 2 B18 ITM, Skunk 2 68mm TB, Delta 272, Xenocron 255 FP, wire tuck, fuse box and battery relocation.
    Re: TDC Sensor
    ^^ Ditto.
    Killa Cali
    Re: TDC Sensor
    I've already tried two different ones, so I'm guessing it has something to do w/ the wiring harness. It was apparently cut and repaired w/ electrical tape, so now I know.
    Jun 2010
    89 Accord DX
    Re: TDC Sensor
    Quote Originally Posted by snoopyloopy View Post
    You'll have to check to make sure its all wired color to color. Theres 4 wires going to the distributor and I would recommend soldering the connections if they arent already and are wired correctly. If not pair it up correctly and then solder each connection.
    EDIT: And use heat shrink tubing to cover the soldered connections. You can find it at like a Radioshack.
    LXi User ecogabriel's Avatar
    Apr 2008
    Atlanta, GA
    Re: TDC Sensor
    TDC sensor: located lower half of distributor. See my thread for EFI distributor overhaul; there are photos of the lower chamber opened.
    x2 for soldered and heat shrink the connections. The sensors can be probed with a multimeter; check the service manual for the values you should be seeing, and which color wires go to what location in the connector.
    From what I have seen inside mine, it is not inconceivable a wire might have broken inside...
    EDIT: Never mind I got it now! problem is in wiring: check the color wiring with the service manual anyway.
    LX User Christofur's Avatar
    Jul 2010
    85 SE-i / 1997 VW Golf
    Auburn, Washington
    Re: TDC Sensor
    i have this code on my 85 SEi i don't know how long its been there. but i have an a20 and im using my sei wiring harness. im 99.9% sure i have it hooked up right. but does anyone have a diagram. i cant seem to find the right one.
    Apr 2008
    Atlanta, GA
    Re: TDC Sensor
    Quote Originally Posted by Christofur View Post
    If your engine comes from an 88-89 you may use the USDM manual -search for it here.
    If your distributor is the A20 distributor, the same manual would have the connector wiring color. But if you are using your car's own wiring harness then you have to figure out which wires connect the TDC sensor to your ECU (I am assuming you are using the 85 SE-i ECU, right?) Maybe the wires are swapped; I doubt the car would run at all otherwise since it tells when to fire the fuel injectors
    Killa Cali
    Re: TDC Sensor
    Quote Originally Posted by ecogabriel View Post
    Yea so I've checked the wiring and the wires that had originally appeared to be the ones that had been repaired in the past were actually for one of the temp sensors. not TDC. TDC wiring is still fine so I figured that cutting into the harness more would do more harm than good. All the wires look good, not visibly damaged, yet I still keep getting the same TDC code. Only other thing I can think of is to go grab a harness from the jy (assuming I can find one unmolested and see if it works. Anyone else have any other ideas, do share. I've done it enough times to know that swapping harnesses is a pain.
    Apr 2008
    Atlanta, GA
    Re: TDC Sensor
    Did you check the sensor itself? The service manual tells you which wires in the plug are for what sensor, and the values you should see when testing with a multimeter.
    I am not sure whether those sensors may go bad, but it would not be a bad idea to test the sensor BEFORE tinkering with the wiring.
    Re: TDC Sensor
    There is actually a diagnostic troubleshooting procedure in the manual. The CEL indicates a problem in the TDC circuit. You have to perform the troubleshooting procedure to find out what exactly is failing.
  1. cylinder position sensor and TDC sensor
    By newaccorddriver in forum EFI Tech
    Last Post: 04-21-2011, 10:02 PM
  2. Coolant temp sensor tw sensor
    By Bluntman in forum 3geez Accords
    Last Post: 07-06-2009, 06:12 PM
  3. cylinder position sensor and TDC sensor
    By newaccorddriver in forum Classic Honda Community Chat
    Last Post: 11-28-2006, 10:29 PM
  4. Need help! Broke a sensor wire (green sensor)
    By SMaurer32 in forum EFI Tech
    Last Post: 10-31-2005, 08:06 AM
  5. Quick, Which o2 sensor is the primary sensor
    By 89accordlxi in forum 3geez Accords
    Last Post: 11-03-2002, 07:23 PM
