Results 26 to 50 of 51
Thread: Best Muffler for this .....
    Re: Best Muffler for this .....
    Quote Originally Posted by SladeHonda View Post
    I think ima go with a magnaflow muffler they have the deepest nicest tone ive heard so far and maybe a cherry bomb glasspack as a resonator and a magnaflow hi-flow cat. I think that will sound great and give some performance boost as well. What you guys think?
    Should be good man. It's all preference really as far as individual components go.
    Feb 2012
    88/honda/accord lxi
    Reidsville, North Carolina
    How are the OBX headers by the way just found some for good price
    Uhhhh okay so the better the flow of the whole exhaust system the more "ricey" it sounds honestly. A solid exhaust system on a 4banger will have a bit of rasp. If u get 2inch exhaust then ut won't be as prevalent. Just think about it, all 4banger sound the same at high rpm just different pitches and tones. Just pick a muffler, get a 2.25 inch exhaust and a long&good resonator and ill be fine.
    Also incar and out of car videos make exhaust notes sound different.
    these cars sound a lot different then most other hondas on the road, I think it's mainly the older engine design plus just a bigger displacement, they also don't need to rev as high as most hondas. These engines were actually designed in the late 70's they just didn't go into production until later,
    Ehh idk what you mean by "a lot". I can pick out most series motors based on my ear and the a series isn't much different, they just don't have as much rasp because of the block design and lover revs.
    And with that being said, throw a can on any stock exhaust 4banger and it's gonna sound exactly the same from the outside. But I I'm being nitpicky here
    LXi User RAZR's Avatar
    May 2010
    1986 accord LXI
    Chicago Il
    Whats a good price? Where did u find them?
    Im looking for obx headers for my car right now.
    Feb 2012
    88/honda/accord lxi
    I found them on eBay for 175 n 25 shipping the pacesetters I was looking at was 222 before shipping and taxes
    May 2010
    1986 accord LXI
    Chicago Il
    OK yeah Ive seen those on there In the next couple weeks Im going to buy one.
  8. #33
    Feb 2012
    88/honda/accord lxi
    cool , I am too but i keep hearing people say they drag the ground are they that low ???
  9. #34
    May 2010
    1986 accord LXI
    Chicago Il
    They do hang lower than any other header but if you at stock height i dont think it will drag. But i guess i will see soon. Even if it does drag just weld a skid plate to the bottom and it should be protected.
  10. #35
    Feb 2012
    88/honda/accord lxi
    Since these pipes slide into each other I wonder if its possible to cut them shorter so there not so low
  11. #36
    Washington
    OBX to me has always built cheaper less quality parts that are substandard. Dave had nothing but problems with his and he needed to modify it straight from the box. If you are buying a new parts built for your use it should work right away and not complicate things more. To buy a new part and have to shorten the downtubes right from the box is a hassle I would chose not to impose. Just get the pacesetter and be happy with the best cheap lowend part that works. The better parts are DC. Expensive and hard to find but worth the expense.
  12. #37
    Vanilla Sky's Avatar
    1999 Penalty Box
    I don't see modifying a header as a big deal. I'm used to working on V8s, and you almost always have to modify them, even good ones, to make them fit right. A pair of V8 headers cost about $250 or so. For a single header for one of our motors that uses less materials and takes less time to assemble, even the $200 OBX is expensive. I can deal with having to cut and weld them. Other than out-of-the-box fitment, the OBX is the best bang for the buck.
  13. #38
    Feb 2012
    88/honda/accord lxi
    Another question I had was does a dual muffler sound any different or is it quieter, louder what, compared to a single outlet muffler. I like the appearance of the dual better but would settle for a single outlet if it has a negative effect on power. I don't mean dual exhaust I'm talking about 1 muffler that has 2 tailpipes
  14. #39
    1999 Penalty Box
    It's mostly an appearance thing.
  15. #40
    3Geez Veteran gfrg88's Avatar
    1986 Honda Prelude 2.0Si-T
    A Mile High.
    Ryan has by far the best sounding exhaust system I've heard on a honda. S&S header to cherry bomb, and turn down right after... but he's also fully built with webers
    -Gio
    My E85 Turbo Build
    5280FEST
  16. #41
    Quote Originally Posted by mykwikcoupe View Post
    there is nothing really wrong with the design of the obx, it looks like bad workmanship is the main issue, it's a copy of the S&S, considering it's stainless steel, it might be worth the effort to repair it, it's easier to modify a header, then to build one from scratch. The issue with clearance isn't a defect, it's the fact that you have four pipes running under the car instead of one. There is only so much room under there, I got mine as close to the bottom of the car as possible, and they are still low. there is no way to modify the bend, it has to be like that. I'm going to coat mine, I have an entire thread up on what I had to go through to get my header in, they are S&S but the obx will be identical. Hopefully the thread will help someone out.
    https://www.3geez.com/forum/showthread.php?t=74744
    aughhhhhh!!! I want to get mine running now, I did the exact same thing, but I built the stainless steel packed muffler and ran the outlet of it to the side pipe outlet. I put the muffler in the same place,where the converter used to be, with the dual carbs, the cam, ignition etc, it's going to sound kick ass
  17. #42
    the reason you can't shorten the pipe on the full tube headers, is the top two pipes just clear everything under the car, important stuff like the oil pan, if you tried to shorten the tubes, the pipes would hit everything under the car.
  18. #43
    Feb 2012
    88/honda/accord lxi
    So all these people who go so overboard about how low they are are really just over exaggerating, i don't plan on lowering the car like that so they would be fine i was just a little weary about them cause so many said bad things about them. Can you lower your car at all with them on there?
  19. #44
    i'm lowering my car three inches, I'll just add a skid plate, there is simply no way for the upper two pipes to go any higher, they just clear the oil pan, the bottom two pipes are stacked under those. There are quality issues with the OBX, the first member to get one on here had posted pictures, one of the ports was hogged out way oversize and didn't match the other ports, along with other issues, I guess it would be easier to fix those then to make a stainless header from scratch. There was someone here who laser cut flanges, cut off the badly made flange and weld on a better one would be one solution. If you don't want the OBX just look for another S&S like I've got, they are still a few around.
  20. #45
    1999 Penalty Box
    I'm with Tim, use a skid plate. I bottom out a stock 3gee from time to time when I drive them offroad, so I should invest in some skid plates anyway.
  21. #46
    dual outlet style like on the Acuras and V6 Accords?
    I need to so something different, mine has that "Briitish ragtop" sound as well sometimes. Im running a Chikara Header, 32 inch glass pack in place of the cat?resonator and then a stock generic 2.50 id muffler. ITS GETTING LOUDER and annoying.
    I think the sheet metal in the muffler catchs that frequency and acts like a reed.
    If you have a cordless sawsall you can get a nice flowmaster or what have you from the pull a part. Look in the donka section, not imports.
    what happens is the fiberglass inside of the muffler burns up and then it gets louder and louder, when I made this mufffler I used the stainless steel wool for muffler packing, it's good to over 1300 degrees and won't burn up or rust out, I know porter makes one like this as well as borla, you might be able to cut open your muffler and repack it, but it's easier to start from scratch,you are right about the metal reflecting the sound, the glass is supposed to absorb that but once it's gone, it just resonates, I wish I had taken pictures of my last glasspack I cut apart, there was nothing left of the packing
  22. #47
    this is why the pipes cant go up any more, this is just below the split in the pipe between upper and lower sections.
  23. #48
    cygnus x-1's Avatar
    Chicago area
    The other day I had an idea for converting an S&S/OBX 4-1 header into a 4-2-1 header. You take off the bottom section and use two Y collectors to join the two left pipes and the two right pipes. Then add a bend after each Y to go around the oil pan. Then run two straight pipes back to another Y right about where the original 4-1 collector was. And finally connect up to the exhaust system.
    The only issue with doing it this way is that the cylinder pairing is sequential (1/2, 3/4) instead of the more conventional non-sequential (1/4, 2/3). Some people claim that sequential pairing can actually give you a broader power band, but there is a lot of conflicting information about sequential vs non-sequential pairing. I'm still trying to sort it out.
    C|
  24. #49
    Accord of the Year - 2006
    guaynabo89's Avatar
    FL
    2.5 is too large a diameter
    Question for you, are you willing to deal with drone from your exhaust?
  25. #50
    LX User Fixedit's Avatar
    Feb 2015
    Oregon
    So earlier in this thread some people went with a magnaflow muffler; which one? I'm looking at the 10444 (chose 2" because the 2.25"s core is still 2"). I cut the flanges off my cat and put them on a long magnaflow glasspack, in place of the cat and resonator. Then deleted the stock muffler, which doesn't sound bad but makes a lot of resonance for long highway drives. I was thinking of the 10444 'cause I can get it cheap and I don't want so much res., and also I only get the sound I like on medium acceleration. I'd rather have something that sounds good all the time
  1. Ok... What muffler is this??
    By Bass Man in forum 3geez Accords
    Last Post: 12-11-2009, 06:49 AM
  2. Anyone know what muffler this is?
    By Bass Man in forum Performance
    Last Post: 06-22-2009, 03:47 PM
  3. Muffler
    By DEEGO in forum Performance
    Last Post: 05-19-2009, 09:58 AM
  4. Which muffler should I get...
    By Dennis in forum Performance
    Last Post: 12-21-2003, 09:01 PM
  5. New muffler
    By carfreak in forum Performance
    Last Post: 09-04-2003, 04:14 PM
