Egr tube, so dumb. Its in the way of the one 12mm to change out that D gasket on the thermostat housing....
so much rage.
lol yeah its a pain.
haha use it as a Cover for the egr...i still have mine but the header doesn't have the screw for the egr pipe haha.
Yeah, it's a fun one. You'll get it if you swear enough. LOL
I just disconnected it from the intake manifold, bent it a little, and use a small ratchet, socket and extension to remove the lower nut.
EDIT: I believe the small ratchet set is 1/4". I should look up the photos I took...
I have to drill that bastard nut though; it was way too tight and I feared breaking the threaded rod (that would have been a bummer)
Worked well, and the last coolant leak is gone
