Results 1 to 12 of 12
Thread: 89 accord suspension issues
    DX User danaragsdale's Avatar
    Apr 2012
    so i have an 89 accord and i just bought some 17 in rims to put on it, but as soon as i went to put them on, i realized the upper control arm is in the way.
    is there a away to solve this issue or do i just need to go back to smaller tires?
    LXi User RAZR's Avatar
    May 2010
    1986 accord LXI
    Chicago Il
    Re: 89 accord suspension issues
    what size tires on there?
    Apr 2012
    205/50 r17
    May 2010
    1986 accord LXI
    Chicago Il
    Your tires are to big.
    215/40-17 23.77” 102.4%
    205/40-17 23.46” 101.1%
    These sizes are the same size as stock. (are pretty close)
    Apr 2012
    theres no possible way to change control arms or anything? theyd work perfectly if it wasnt there
    May 2010
    1986 accord LXI
    Chicago Il
    Quote Originally Posted by danaragsdale View Post
    Nope there all the same. did you just buy those tires?
    Apr 2012
    yeah, sadly.
    what offset are they? You might be able to get away with using wheel spacers
    I think your rims are the wrong offset if I'm reading correctly. there are some stickies on the top of the page should tell you what offset is correct. I think its is +35 mm.
    You wont find any 17" tires that are stock or really even close to stock overall size because I have been looking for 10 years. Close is atleast one inch oversized.
    LX User vteckiller's Avatar
    Oct 2011
    1989 Honda Accord LX-I
    OR
    I've got Motegi 17 inch rims with 205/40/17s on them and they dont rub one but anywhere, they're practically the same size as a 205/70/14.
    anywho here is the info on them..
    Motegi MR125 black 17x7.5 4x100 4x4.5 Offset 42 Hub Bore 72.60
    LIFE IS SHORT, DRAG IT OUT!
    May 2010
    1986 accord LXI
    Chicago Il
    from the online tire size calculator
    The reason your rubbing is cause your new tires are almost 1.60 inches taller. I think your prolly gunna have to get new tires and recoup your losses by selling the current tires on ebay.
    Quote Originally Posted by vtechkiller View Post
    195/60/14 was the stock factory size. 23.2 inches over all.
    205/70/14 25.3 inches. That's 2 inches taller. It effects your overall gearing in my opinion negatively.
    I think 185/70/13 was also the stock size on the DX model.
  1. 89 Accord LXi idle issues
    By pacmannproductions in forum EFI Tech
    Last Post: 10-13-2012, 05:07 AM
  2. Won't start when hot and NoX Issues ('86 Accord DX)
    By crazylikeacat in forum Carburetor Tech
    Last Post: 06-21-2012, 09:11 AM
  3. 85' Honda Accord issues
    By BoardroomMotorsports in forum 2geez Accords
    Last Post: 05-04-2009, 10:03 PM
  4. '89 Accord LX, have a few issues
    By JuggaloZeke in forum 3geez Accords
    Last Post: 04-04-2007, 03:18 PM
  5. issues with the accord lxi
    By 86-accord-lxi in forum 3geez Accords
    Last Post: 10-11-2005, 03:24 PM
