On my 86 Prelude Si it feels like total sh*t while idling at 750 which is suppose to be the normal idle on the car, but say if i start it in the morning it idles at 2k for like 2 seconds and then drops to 1500 and sounds and feels fine on idle and driving
But ive been noticing when it finally idles at 750 it feels all sluggish and even when i shift it feels a lil rough. It never really idles at 750 but only after i drive for a long time usually stays around 1k idle.
Ive had a clutch/flywheel replaced like 3 months ago, altenator was replaced 2 months ago, on a 2week old oil change right now, just changed my injectors which were used but tested and worked perfectly(problem was before injectors also) and changed my fuel filter. Timing belt was replaced also forgot when exactly. Also forgot to mention spark plugs and wires were replaced 2 weeks ago along with the oil and filter and also the valve cover gasket if that matters.
What causes this, it feels really good and smooth when its idling a bit high but total shit on normal idle
