Results 1 to 5 of 5
Thread: Need Help To Get Dip Stick Out Of Auto Trans
    bridgewater.NS Canada
    Question Need Help To Get Dip Stick Out Of Auto Trans
    Hey guys I'm trying to get the dip stick out of my auto trans but it won't budge.Was thinking of cutting a notch in a piece of pipe and putting a pipe wrench on it but don't want to break anything.Any advice would be appreciated.
    SEi User gp02a0083's Avatar
    1989 Lx-i Hatchback
    Jackson, NJ
    Re: Need Help To Get Dip Stick Out Of Auto Trans
    I used a set of needle nose pliers. They couldn't have put this in a better spot, just like the coolant lines under the intake manifold
    Just put some trans fluid on the dip-stick's threads, i never had a problem after that, kinda works like anti-cease
    3Geez resident body man
    Owner of Wreck-less auto body
    Nov 2000
    Whenever I break mine loose I have to use a pair of regular pliers. Maybe some teflon tape on the threads would prevent it from seizing in the future. In fact, I am going to do that next time. When my rebuilt unit was installed three years ago the mechanic added a Magnafine inline filter. That thing is big and it ended up right above the "dipstick" handle. What a pain. When I changed my fluid a couple of weeks ago I replaced the big Magnafine filter with this one.
    http://www.atp-inc.com/LinkClick.asp...sg%3d&tabid=81
    I got the JX-154 from Rock Auto.
    I wouldn't put teflon tape on transmission part since it can make it's way in and cause problems.
    I would try some heavy linemann's pliers those are narrow enough to go in, wide enough to grip the dipstick tab and heavy enough to enhance your wrist twist with less trauma to the stick and your knuckles )
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    not sure if you noticed but my cap has a hole drilled in it, I use the hole with a screw driver or Allen wrench to help loosen it. Also made my car 0.0002% lighter
  1. Auto to stick tranny swap! :-)
    By Qthestuntman in forum 3geez Accords
    Last Post: 04-06-2007, 09:00 AM
  2. auto trans
    By 3vg in forum 3geez Accords
    Last Post: 12-05-2003, 12:46 PM
  3. wtb: auto trans for a 3g
    By TDS715 in forum Trading Post
    Last Post: 11-10-2003, 12:56 PM
  4. Auto or Stick?
    By Soccerguy2005 in forum Classic Honda Community Chat
    Last Post: 09-20-2003, 05:03 AM
  5. Auto shift stick appearance.
    By Defiant[YD] in forum Interior & Exterior Care
    Last Post: 06-26-2003, 08:49 AM
