Not sure if this problem qualifies for this area.....
I just changed out my nasty fuel filter today along with my injectors was a very simple job to say the least, but when as i was taking off the bolt to relieve the fuel pressure (6mm bolt that is screwed on top of the odd shaped banjo bolt) the bolt stripped pretty bad and couldnt use a 12mm socket on it anymore and had to use these vice grip thing, so now my problem is when i replaced the filter and put that screw back on on top of the banjo bolt a very tiny amount of gas comes out, almost like vapors and not in drops
I found a pic that shows which screw im talkin about
Anyone know whats a good replacement because the dude who said he just bought a replacement bolt for his at a hardware store had pressure problems still.
Here link to pic http://www.preludezone.com/attachmen...banjo-bolt.jpg
