Something else I learned today.
Incandescent bulbs and LED's are the only kind of bulbs that the light output decreases over time. An LED's rating (40,000 hours or so) is the lifespan of the bulb until they have dimmed to a point that the human eye can perceive the difference. They will continue to burn on, even when they put out no perceivable light, or until the driver burns out.
An Incandescent bulb's rating (usually around 1,000 hours) is until it completely burns out. Around 800 hours and you will notice it is significantly dimmer, if your paying attention.
Halogen bulbs (about 25% more efficient than incandescent) and CFL's (about 75% more efficient) have no perceivable drop in light output. They have their flaws (halogens get really hot, burn out if you touch them, don't have a long service life, etc) (CFL's have to warm up, aren't dimmable usually, have mercury, etc) but they are worth it.
Here's some math for your enjoyment.
Average bulb use: 3 hours per day
60 watt incandescent bulb (60 watts per hour, thats how they are rated) x 3 hours per day x 365 days = 65700. Thats 65.7 KWH, or $7.22 per year, per bulb. (figuring .011 cents per KWH, which is the national average.) Also add .50 cents per bulb, considering you will replace these about once per year (we will say once every two years, for arguments sake, so .25 cents.)
Your at $7.47. PER bulb.
Switch to CFL's
60 watt EQU uses 13 Watts
13 X 3 X 365 = 14235, 14.235 KWH = $1.56. Factor in the price of the bulb, we will say $3 if you are paying way too much.
$4.56. But wait. You only have to replace these every 7 years (if you aren't buying them from Walmart, lowes or home depot) Divide that $3 by 7 ($0.42)
In reality, these only cost you about $1.98. EVEN IF you have to replace them every year, you come out ahead in energy costs.
Sorry, passionate about these. I wear my wife out looking at bulbs every where we go!
