Results 1 to 11 of 11
Thread: 5th gear
    Sep 2010
    1989 Accord DX 2dr
    5th gear
    I read about people having 5th gear go out in their trannys. Can i remove the 5th gear portion from my car and save it since i am going to scrap the car in the next week or so? Or would it be easier to remove the whole tranny? I plan on getting another 3G down the road and plan on keeping some spares from this car that i know are working or recently replaced. thanks for all the help you guys have been.
    Re: 5th gear
    yup you can get 5th gear out, you don't even have to pull the gearbox off. just that little black cover on the end of it is what houses the 5th gear
    Vanilla Sky's Avatar
    1999 Penalty Box
    Re: 5th gear
    In the case that you don't get another 3gee, you can probably sell that 5th gear cluster to someone with an Integra that wants a longer 5th gear for highway cruising. I've sold a couple to Integra owners.
    Sep 2010
    1989 Accord DX 2dr
    Re: 5th gear
    What all is removed when you take the 5th gear out? I want to make sure I get out everything I may need. Thanks again
    1999 Penalty Box
    Re: 5th gear
    5th gear cover, 2 nuts, and some other various hardware. 5th gear sits outside of the main transmission case. The service manual will walk you through the procedure.
    AZmike's Avatar
    Jul 2002
    Tucson, Arizona
    Re: 5th gear
    A 30 mm socket and a 5mm (3/16") drift are the most unusual tools you'll need.
    Mike
    Re: 5th gear
    5TH gear. Should be able to remove it as long as you have space to fit the 30mm socket. You may have to separate the driver's side mount and tilt the motor
    Eric
    Oct 2014
    Re: 5th gear
    I have a similar problem. I have a 89 sedan accord that wont get the reverse gear. Could i do something similar? Do i have to remove the whole tranny or just the gear box
    Re: 5th gear
    Sorry, the reverse gear is deeper inside the trans.
    Mar 2003
    2004 Acura TL
    Arkansas
    Re: 5th gear
    Quote Originally Posted by kumartypeR View Post
    Reverse gear isn't synchronized, so if the clutch drags a bit it's hard to get into gear. Will it go into gear if the engine isn't running?
    DX User pajamas95's Avatar
    Jan 2014
    1987 Honda Accord LX
    Riverside, CA
    Re: 5th gear
    On my car, it will not want to go into reverse unless I put it in 1st first. I do it out of habit now that I haven't even bothered to fix it as it is so fast. You should try pushing the clutch in, stick it in first and then directly in reverse and see if it helps.
    1987 Accord Sedan LX KL 5MT in Sonic Blue Metallic - 2.5" lowering springs
  1. GE Cam Gear
    By Vanilla Sky in forum For Sale
    Last Post: 12-12-2010, 09:52 PM
  2. Gear
    By NC 85 3Door in forum 2geez Accords
    Last Post: 07-22-2009, 06:45 AM
  3. WTB: GE Cam Gear.
    By markmdz89hatch in forum Wanted
    Last Post: 03-05-2009, 07:50 AM
  4. 100 in 4th gear
    By hondarider88 in forum Performance
    Last Post: 01-19-2003, 12:51 PM
  5. adj. cam gear pic
    By guaynabo89 in forum Classic Honda Pics & Videos
    Last Post: 07-05-2002, 12:35 PM
