Working on a "drop-in" LED prototype 1156.
This one is a proof-of-concept for amber turn signals, I'll call it "Style A"
"Style B" is in the works, and then I will start on the 1157, which will be interesting...
while I was at pick and pull, I happened to notice that the round relays on later Toyota stuff, are a match for the sub cooling fan relay on LXI's, which is discontinued, they number the relay different, but it's actually identical,as far as mounting, pin locations, rating etc, the Toyota one is numbered 90987-02004 and it's a Denso, on the Toyota relay they number the coil as pins 1-3 and the contacts as 2-4, on the LXI relay they number the pins as the coil 1-2 and the contacts as 3-4 but the terminals are actually in the same location on both.
Currently working on a few brackets that have started showing signs of rust i.e. Coil bracket, IACV brackets, spark plug/VC bracket and a few others. Covering them with fresh paint as well.
Shaggy
FF II/ETC I
