Results 1 to 17 of 17
Thread: Multiple "auto down" windows.
    I was reading this thread, and it got me thinking that this may be a possibility. Looking at the electrical diagram the only difference is the drivers window motor, and switch. I'm wondering if those could be swapped out to allow the passenger (or rear) windows to be auto-downed. I'm not even sure how the motors swap, but if its a bolt on thing this could be an awesome mod. I have not even taken apart the window switch yet to see if it can be replaced with two AD switches.
    Re: Multiple "auto down" windows.
    I want to look in to this, it never occured to me to do it.
    I have this ritual of motions of putting the windows down when im leaving work so it would be cool for quick touch windows all around.
    What would be even cooler is power rear hatch pop outs ehh?
    I was thinking maybe we could wire it so one AD click on the drivers switch will roll all the windows down, and a non AD click would just roll the drivers down.
    I never got to look into this but a lot of early datsuns had slide controls for the rear quarters, a couple of small linear actuators and you are set
    That's a lot of amperage at once, Im not sure the control module would stand that. I only say that because one time a while back somebody was using the pass side button the same time I was using the master and it tripped something. After a while it started working again.
    Im not saying it can't be done but only something to consider if it comes to troubleshooting it later.
    Nov 2000
    Somebody else on this forum modified the driver's window switch to add an auto-up feature. If you find that post you might be able to use the same process to add auto-down and/or auto-up features to all windows.
    While I was searching online for a replacement power window control box I noticed several "universal" control boxes. They are usually added with alarm systems, but they look like you could use one in place of the OEM box to be able to lower your windows with a key fob remote. Pretty cool if you like that feature on new cars.
    Feb 2011
    89 Dx, 89 LXi
    New West
    http://www.directed.com/guides/manua...N530T_1-00.pdf
    Good unit, really decently priced. Use one for the back windows, another for the front passenger. Can probably wire it all in on the drivers door after the switches.
    Nov 2000
    Good find! I thought about using one of these "universal" control modules. Figuring out how to install it is within my capabilities, but since I found a new one online I took the lazy route. I rarely operate my windows and park in garages at home and work. Plus, I only have two power windows on the coupe. My window motors probably have the wear of ones on a car half its age since I rarely use them.
    You were right DB looks like this has already been determined. Here is the thread
    i've done this mod
    you need 1 driver's door motor and 1 driver's motor control box,
    it needs to be a mitsuba with 6 pins, not the united 5 pin one
    install the driver's motor into the pax regulator
    remove the pins in the pass motor plug and reverse them so the switch operates correctly and add a ground wire from the box to the door
    wire down wire to auto down pin
    wire up wire to auto up pin
    on the driver door just move the up wire to the auto up pin
    when you hit up or down it will go auto all the way up or down
    to stop it inbetween just hit the switch the opposite direction while it's moving and it will stop
    This won't work on the rear doors because the motor is too big
    Eric
    oh this is for auto up and auto down
    If you don't care about auto up you can use the united box with 5 pins
    Eric
    These cars don't have auto up?
    no, but the japanese Mitsuba controller has the capability, it just isn't wired up
    Eric
    Never got to doing this I was just telling a buddy about this. I have the 6 pin as well. Lucky me lol
    i don't know why the imageshack button is such a PITA
    here's a scan from my manual
    pm me if you want the full size
    Eric
    Grab a driver's motor (no regulator needed) and control box with mounting strap and the 6-pin plug.
    you can tap power (WHT/YEL) for the controller from the BLU/BLK wire and ground (BLK) it to the mounting screw. cut the wires going to the passenger motor. then you connect the following:
    switch up (BLU/WHT) to controller up (BLK/YEL) or auto up (RED/YEL) (6-pin mitsuba required for auto up)
    switch dn (BLU/RED) to controller dn (BLK/GRN) or auto dn (RED/GRN)
    Then reverse the power wires in the motor's plug or else it will operate backwards
    Eric
  1. Classic "Taxi". Good ole Jim. "What does the yellow light mean?".
    By Bluntman in forum Classic Honda Community Chat
    Last Post: 06-28-2012, 12:21 PM
  2. SH4D0W's 86 LX-i Sedan Auto-X "Project Little Red"
    By Sh4d0w in forum Project Central
    Last Post: 08-03-2010, 04:17 PM
  3. "Auto-Up drivers side window switch" mod question
    By Bones in forum Interior & Exterior Care
    Last Post: 08-02-2007, 08:28 AM
  4. '86 LX(auto) with A18A "JDM" engine?
    By Cygnus in forum General Engine Swaps
    Last Post: 07-09-2006, 06:20 PM
