Hello everyone. So I got the engine in the Accord but now have 2 strange issues.
First is the starter won't turn over. I can hear it click and have checked for voltage at the plug and cable but nothing happens. The engine spins freely when it's turned with a wrench with the plugs out.
Second issues is something went wrong with the alternator harness and the black wire (I'm guessing ground) ended up melting all the way up to the junction on the main harness. It appears to have stopped there and I cannot see any other melting of the harness when I pull the tape back. The connection to the large white wire next to it appears to have crept out of it's connector and may have bridged with that black wire? That's my only guess at this point since it stops shortly after the plug.
Also that Petronix Ignitor almost caught on fire with the key being on for around 2 seconds. The instructions were very vague and the kit did not fit on my car properly. If you have a car with electronic ignition do not try to replace it with this kit.
So any ideas on the starter or alternator? I'm running out of ideas at this point.
