So basically what's going on is whenever I start the car, it idles rough like its missing. This only happens on cold starts. I found a vacuum leak at the base of the carb so I will be replacing the gasket ASAP. Until then I have adjusted the idle a little higher to keep it from stalling out itself. It will idle terribly until I put it in gear and actually drive it. Then it's normal until I let it sit for a few hours. I think something may be wrong with the choke but I'm not sure. Any input or suggestions? Also, how do I adjust the choke on the carb? Thanks guys.
