Results 1 to 25 of 29
Thread: Now THIS is an AMP!!!!!
    3Geez Veteran 87AccordsterLx's Avatar
    Nov 2001
    1991 Supra Turbo W/ 12k Miles
    Wyotech @ Laramie, WY
    I'll let the description justify how amasing this amp is.... it looks so same good on top of it.....
    http://cgi.ebay.com/ws/eBayISAPI.dll...tem=1386260136
    ~Nathan~
    ~StOcK PiCs~
    SEi User toastyghost's Avatar
    Mar 2002
    a 93 z34 that's getting parted out, an 86 accord lx that now lives in a j/y, and a 90 camry le that the state no longer allows me to drive. soon to be replaced with an aprilia rs50 or a derbi gpr.
    Harrisonburg VA
    the car will look gay with an outboard gas generator to power that bitch though..
    ~<+045+ygH05+>~
    Nov 2001
    LOL!!! true...true... If I ever got into competition though... I would murder peoples shit with two eclipse 15's and that Amp...
    ~Nathan~
    ~StOcK PiCs~
    SEi User jigga225's Avatar
    Louisiana
    man we cant do nothin wit that...
    we only a have 65 amp alternators.
    That damn thing would pull over 130A!
    Nov 2001
    yes but we can put more powerful alt.'s in our cars....
    ~Nathan~
    ~StOcK PiCs~
    and where can you get one?
    show it to me.
    Nov 2001
    well first off the amp mentions that it will peak in the area of 50A... second... a 1990 accords Alt. runs 90A and will physically fit in our cars....
    ~Nathan~
    ~StOcK PiCs~
    Mar 2002
    Harrisonburg VA
    Sounds like a howto project in the works. I'll be damned if I'm doing it though, I just replaced my alt. :P Maybe we could draw straws...
    ~<+045+ygH05+>~
    hmmm, i think my local junk yard has the 1990 accord.
    i have to check on that one.
    that would be awesome if it does fit on our engine.
    Nov 2001
    ...... here is a link that I found a while back which led me to that conclusion.... it is actually the same senerio that we are discussing...
    http://autorepair.about.com/library/faqs/bl186c.htm
    ~Nathan~
    ~StOcK PiCs~
    10/Honda/Ridgeline
    NJ
    but u see, efi guys can swap it if they want to because the altenator has 4 pins in it. but our 3g carb has just 3 pins in it. so a 4g accord altenator, no matter its a dx, lx, or a ex or even a se. it just wont fit on the carb cars.
    Nov 2001
    hmm... interesting... I wonder if there is someway to work around that....
    ~Nathan~
    ~StOcK PiCs~
    Mar 2002
    Harrisonburg VA
    Since the alternator and the type of fuel system shouldn't directly affect each other, I would assume you can ground something to make it work.
    ~<+045+ygH05+>~
    2.0Si User Grant2k's Avatar
    i think that you can use it and just not hook up the last post. there is a thread about distributors somewhere that mentions that.
    SEi User 87DXHatch's Avatar
    '92 Toyota Paseo
    St. Paul, MN
    Alright, you have to factor ~10 amps for every 100 watts of power... this is why you can burn out your alternator running a 900 watt amp. That amp would be very nice... but it would require a bigger alternator.
    As for the 3-pins over 4... I read on here that it makes no difference, the extra wire on the 4 pin goes to the ECU for FI cars, so it just runs to nothing on Carbed cars. I am very interested in the findings on whether a '90 Accord alternator will fit, because I am in need of upgrading mine.
    Nov 2001
    YEAH!!!! Did I find out a new mod or what????!?!?
    ~Nathan~
    ~StOcK PiCs~
    87 Lx-i
    New Orleans, La
    i've been lokking into this...
    Extreme Boredom
    3Geez member since July 2001
    My Car
    after drop
    i like the part about 5 minute installation.
    Nov 2001
    Bluecoma... what drop are you running??? are they coilovers?? Your car would look sooo clean with some clear blinker signals and cornermarkers with some 17's or 16's on it.... nice job though....
    ~Nathan~
    ~StOcK PiCs~
    Oct 2002
    '89 Prelude Si 4WS
    Gig Harbor, WA
    however long it takes you to install your stock alternator, that's how long it will take you to install that mean green one... on my lude, it takes a bit longer than 5 minutes, as i'm sure most of you know, cause i do believe you guys have your alternators in the back of the engine...
    you could always take your alternator you have now to a shop and have it rewound to a higher amperage... most heavy bass applications you're going to want more than just a 20 amp or so bump on your alternator... i didn't look at the specs on that amp, but i'm betting that you will be way underpowered with a stock or even a 90 amp alternator... i'd go something like 120 if you plan on seriously bumping...
    http://www.merlindavis.com
    Nov 2001
    hey merlin... you should throw on sideskirts and the rest of the rear kit on that lude... it would Stock Car style.....
    ~Nathan~
    ~StOcK PiCs~
    Oct 2002
    '89 Prelude Si 4WS
    Gig Harbor, WA
    if only that lude were mine!!!! that's an old King Motorsports track car... car is lowered, probably 'bout an 1" and a half, that big ass lip keep the front end planted, pretty much just a big extension off the stock bumper... and there's no real reason to have sideskirts and a rear on a car where how pretty it looks isn't an issue... as for stock cars, NASCAR, even though they aren't anywhere near stock, doesn't have rear ends... same thing with CART and F1, if you have too low of a rear end, the air below your car doesn't find it's way out the back end and you lose alot of possible downforce...
    87 LX-i
    Akron OH
    just get a cap and a 2end battery
    LX User Nate2310's Avatar
    Oct 2002
    what?
    You think no one could compete w/ that amp and 2 15' eclipses??????
    What about 2 15" JL's? If you put 2 JL 12" to your ears at full power you will go def
    I think that the JL's would completely over power those "eclipses"
    Nov 2001
    first off... the emphisys was twards the amp more then the speakers... second I wasnt being technical someone can always compeate with you no matter what... theres no question that JL subs are good subs... shit their 13w7 can handle 4000w .... thats not the point... the point is that eclipse puts out amasing electronics... far superior to JL... if you ever go to custom car audio and sound shows... look inside their car at their H/U... your definitly not going to see JL thats just not possible ... it will most likely be Eclipse.... look at thier amp... hmm if they wont to push more then 1000w with one amp its sure not going to be JL.... the fact of the matter is... you cant find a JL amp that will out perform an eclipse... 2 eclipse subs will handle the amp that I posted just fine... go see if your 1000w JL will compete with the 2000w amp that I posted... haha... good luck
    JL
    ECLIPSE
    ~Nathan~
    ~StOcK PiCs~
