Since summer has arrived, I though I might share a cooling system tip that I haven't seen get enough publicity. On my 89 LXi, the fans were cycling on and off about once a minute. This was on a 75 degree day, mind you with no A/C. It was one of those "Oh No" moments, as I realized the cooling system was gonna take a dump. I blew out the rad fins with the compressor, and blew out a ton of bugs/leaves/etc, but that didn't help. What fixed it was:
Bleeding the cooling system!
I hadn't done it since the last time I changed the coolant, so I assumed it was all bled out. Apparently I missed a bit. I don't think it was making the car overheat (Who knows, with our dummy gauges) but it was sure screwing with the sensors! Just thought I'd share a quick fix for what is sure to be a common problem in the coming months, at least in the Golden State.
