Originally Posted by
H2289Acc
Actually, I was originally going to go with the straight-forward itr caliper upgrade until I did a lot of research. This conversion has been done on a lot of civics, itrs, 4th gen v-tec ludes and 5th gen accords. From what I've read, the civic and 5th gen accord calipers are mounted the same as ours, on the front of the rotor. Trick is to bleed the calipers while they're off with the bleeder facing up. Apparently after they're bled, they can then be mounted upside down without any issues. As far as the brackets go, there is a thread that lists all the caliper/bracket combos that are compatible with our cars, the 91-96 NSX and 95 Legend GS included. I have a set of itr calipers and brackets laying around so I did the comparison to the GS brackets and the bolt spacing is in fact the same. Also, I had originally ordered the redrilled 89 Legend rotors from Brian at Fastbrakes, but before they were shipped, I found out I could use the thicker v-tec lude rotors (23mm as opposed to 21mm) which are more suitable for the itr or gs caliper upgrade in terms of brake pad spacing.
I'll post more pics and let you guys know how it goes when I get around to the install.
