hello friends.
i have a "CRV" distribuitor TD-74u from b20b engine
my question is whether this distributor will serve in my "B20A" OBD0 ??
and if it is made to function as the inner coil left running ..
regards
attached images.
hello friends.
regards
attached images.
I've never had any issues from using a obd1 dizzy on a b20a with stock ph3 ecu, you should be fine. If you have a hood liner in the car, the top of your dizzy will probably rub through it
But doesn't the B20B use OBD2?
I don't know, I've never seen an obd2 distributor on an obd0 engine/ecu.
oh okay didn't know that lol. i suppose as long as it has the required sensors in it (which looks like it going by all the wires coming out of it) it will work.
