Results 1 to 9 of 9
Thread: power steering delete need help !!
    LX User 247shuer247's Avatar
    Feb 2011
    1986 accord lx-i
    Unhappy power steering delete need help !!
    okay so i recently did a engine clean up the last thing left to do is completly remove the power steering system before i had just cut the belt.
    i removed everything including the pump but im having trouble removing the last hose its the one that goes from the pump and wraps around the block and ends up right underneath the fuel pump. i cant for the life of me figure out how to get it off...
    also when doing the research for this i kept hearing people say to make your own reservoir and to loop the lines what the heck does that mean ?
    any help is appreciated and pics would be a great help
    thanks guys
    ''YOU MAY LOSE MONEY CHASING WOMEN BUT You will no doubt end up broke as a mothafucka chasing cars''
    Re: power steering delete need help !!
    #8?
    I think it goes into the steering rack and there is a clamp that holds it, look for the bushing
    Feb 2011
    1986 accord lx-i
    i gave been looking for this diagram everywhere thanks so much.
    would it be unclamped or unscrewed ?
    have you also done a power steering delete POS?
    Nov 2000
    There are two u-shaped brackets with rubber bushings in them that hold the metal portion of the line on the rear crossmember. Each has two small bolts securing it. They are a pain in the rear to access. When I replaced my line I just didn't put them back and it was all fine.
    Feb 2011
    1986 accord lx-i
    awe man what size are the bolts ??
    thanks for the help. i was honestly about to just cut the damn thing lol
    is this something i really have to raise the car for ?
    No I like my a/c and p/s
    I ran around with no p/s for a while and it kind of sucked, but the worst part is that it wears out the "rag joint" at the base of the column which is about $100 from Honda and a PITA to replace
    it's gotta be an m6 with a 10mm head
    Nov 2000
    Sorry, there's only one bolt in each (parts 23 and 34 in the diagram). You would use a 10mm socket as Eric surmised. There a lot easier to remove than they are to reinstall.
    Feb 2011
    1986 accord lx-i
    well should be no problem i dont plan on putting it back lol
    thanks guys
  1. Good lord power steering sucks power!
    By 87DXHatch in forum Classic Honda Community Chat
    Last Post: 08-30-2005, 05:20 AM
  2. Power Steering...
    By fl_lunatic in forum 3geez Accords
    Last Post: 03-15-2005, 08:47 PM
  3. Power Steering Help
    By Tespo87AccordDX in forum 3geez Accords
    Last Post: 12-23-2004, 07:06 AM
  4. Power Steering. . power loss?
    By bboipinoy112 in forum 3geez Accords
    Last Post: 08-11-2003, 07:47 AM
  5. power gained from removing power steering?
    By Mantis88LX in forum Performance
    Last Post: 04-10-2003, 06:50 AM
